WONT START
4WDKC
Southern Florida
Kacy
Here is your sending unit
that silver thing in the middle is the check valve that prevents fuel from entering the evap line to the canister. If that is removed you could have the issue you are describing. If someone tried to bypass the tank switching valve they may have plumber the return line to the evap line on accident, possibly?
My truck was pushing fuel out the top of the sending unit and it wasnt going to the canister. Youre going to need a manual and have to get onder the truck to figure this out.
San Angelo
Steven
sierra classic 1500
Something is very wrong... do you have a dual tank truck? Can you use both tanks? Did someone try to bypass the switch valve?
Yes it does and the person I bought it from said, the switch wasn't working so they only set it up to use the drivers side tank and put a new fuel pump in too
San Angelo
Steven
sierra classic 1500
I'll look exactly how they did it exactly
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Missing some hoses on that canister. what are the ones that are on there actually connected to?
San Angelo
Steven
sierra classic 1500
(Based on photo ) the one on the top goes to the fuel tank. The bottom goes to the TBI middle one is to atmosphere
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Do you happen to have an air cleaner/ tbi port capped? Because the middle one (that you are atmosphere venting) should be routed there.
jimlayhee
