Wiring questions! Help!
crpntr78
Missouri
Hello? Can anybody answer the above question? Thank you.
robert8096
Goose Creek SC
Robert
Good morning, Here's another question. I'm wanting to change over from a 2 light to a 4 light front end. Outside of having to get a 4 light core support and wiring harness is there anything else I will need to make this conversion? Will the fuse block accomodate the extra headlights? How about the switch? Trying to get all my ducks in a row before starting this project. Thanks for any input.
If you are going to use the stock seal beam headlights in the conversion you should be good to go. You can re-pin you existing single headlight harness to work with the quad stock headlight mod. If you are going with a halogen headlight upgrade then you will want to go with a relay harness.
crpntr78
Missouri
Thank you very much for the information. Really appreciate it.
DawgmanDew
