jwill945
- Aug 14, 2021
- Jonesboro
- Josh
- GMC Jimmy
1976 GMC Jimmy
Intermittent no crank/no start problem. I found 2 bad grounds (from battery to alternator bracket was pulled out of battery terminal and engine to cab was off). I repaired the one to alternator bracket and reconnected the one from engine to cab. Still have issues.
My next thought was ignition switch. So pulled gauge cluster to make sure it wasn’t lose or rod twisted up. PO put in Equus gauges and they were silicones in place with wires duct taped together. I pulled all out except Speedo/odometer and oil pressure gauge. Still nothing.
Then I went back to battery. Has good grounds per the multimeter, but wire to starter was twisted at starter. With key on, I could move wire and hear it arc. I removed that but can’t find any replacements. I see it should have a fusible link, but have no idea where or how to make one.
Anyone have a good source or tips on how to make this wire?
