Wiper/ turn signal switch
Layne02
Ga
Jeff
R1500
New dimmer switch is on the way, will update this weekend when I get it in, thanks
Caution!! Before proceeding with the above highlighted step, disconnect the little shift indicator cable where it attaches to the shift lever collar.. Not doing so will damage the shift indicator..
Oh yeah, thanks Nick. That was the Cliff Notes version and unfortunately that step was omitted:
3. To drop the column you'll need to release the clip on the end of the gear indicator wire where it attaches to the bowl shroud:
Also, make a little mark showing the location of the clip on the shroud. Upon reassembly, that will save you from having to realign the shift detents with the letters on the indicator. Do it now, so you don't forget!
Full procedure for column removal:
http://www.gmsquarebody.com/threads/87-r10-steering-column-upgrade.17912/#post-334762
Layne02
Ga
Jeff
R1500
Got new dimmer switch , hooked it up and tada!! high beams back working, thanks everyone
ben_swager
