Wiper Pulse Module #15598496
Doppleganger
OH-MI: Just like it sounds
Local guy I know works for IBM. He builds custom made Fanuc controller boards. I gave him my module to go over and double check - he said they're very basic and would be easy to even duplicate. fwiw....he made a custom FI controller for a 1970 D-Jet injection car, from an original empty case and a schematic, so doubt this would be much of a challenge for him.
Wonder what a 'new' one would be worth? Might try and talk him into it.
SquareRoot
they are still available new
- https://www.workhorseparts.com/15598496-Module-Asm-Wiper-Switch-Pulse-Control
I ordered one of these and replaced mine. it didn't fix my issue, which was either the circuit breaker or park switch in the motor. but this is a direct replacement.
I ordered TWO of them (AC Delco) from Rockauto) and BOTH them POS' were defective. Tough pill to swallow at $79 each and no returns on electrical items. Pass
Doppleganger
Wonder if they were refurbs? I dont go near the remans....they take a 300k accessory, replace whatever broke - new sticker and you have a component that is 90% 300k and 10% new.
gmbellew
Kansas city
glen
suburban 1500
how do you know they were defective?
SquareRoot
Because neither one fixed the issue yet I could swap a known good module from my buddies truck and it worked like it should. Then I put both new modules in his truck and his didn't work.
gmbellew
Kansas city
glen
suburban 1500
got it. mine didn't fix the issue, but I left the new part in. i installed a new motor and that fixed my issue with the delay function. I did save the old part just in case. good thing, because apparently it is still good...
SquareRoot
What was your issue? Mine won't run on intermittent, only low and high.
gmbellew
Kansas city
glen
suburban 1500
wiper motor. it has a circuit breaker and a park switch in it. one of them must have been bad. prior to replacing the motor, I had the switch in the column replaced because that seemed like the next likely culprit. but the issue was still there. the internal stuff on the motor was all that was left to replace, and that did it.
my issue was also only the delay function. hi and lo worked fine.
Had to have been the park switch. Without it, the delay module doesn't know when to cycle the low speed. But that is always an obvious issue because you have to turn off the wipers at just the right time so they stop at the bottom of the glass.
gmbellew
Kansas city
glen
suburban 1500
yeah, the wipers parked fine in hi and lo. i dug through the repair manuals and the on board circuit breaker is part of the testing because I guess it can get weak. I figured that was the likely cause of the pulse not being long/strong enough to get the wipers out of park until after 2 or 3 pulses. and maybe the park switch was a little bit out of adjustment after 30yrs. it was a long road to repair considering I was 90% sure it was the module that I replaced first :banghead:
Scott91370
Burleson, Tx
Scott
Sierra1500
Mine won't park but I don't know if this would be the issue or the wiper motor. I haven't ever tried intermittent.
gmbellew
Kansas city
glen
suburban 1500
Mine won't park but I don't know if this would be the issue or the wiper motor. I haven't eve tried intermittent.
if it won't park, I'd suspect the park switch in the motor assembly. if you are very talented, you may be able to get in their and fix it. but if not, I think my replacement motor was less than $100...it was a cardone rebuild, but seems to work well.
Andreas Wickman
Sweden
Andreas
I fixed mine (or a friend thst can electronics did) a couple of years ago on mine C20 diesel 1983. I will say that the feature that electroncs add to the truck means a gretet improvment than one should expect. Five nice functions, for example I do like the one side push left and you wipe once.
Crazylogix
Missouri
Damon
I fixed one for a friend at work, thanks to this post it was easy. Made a quick video about it.
Crazylogix
BALLTURRETGUNNER
