Will a 8.5 Camaro 10 bolt axle fit in a 1981 squarebody?
Looks like 8.5 verify your rear has the same lugs in the same spots and start robbing parts keep your shims matched to where they came from to aide in setup. Don't tear in to the truck rearend immediately,get your parts together. Then I'll give some instructions on things to mark measure and make notes on to ease the setup.
Ryanbrown36
Ontario, Canada
Ryan
c1500
Ok thanks, really appreciate the help, will check my rear end tonight and if I buy the rear end will let you know. Thanks
BRB okay was going to write this for you. But ended up writing it for someone else. Here's your basics. I'll give you more tips,trucks and details as you go.
