da_raabi
Trailer Park Supervisor
- Aug 7, 2013
- FloriDUH
- Adam
- c30
Green79, thanks for the check on that tire size, yea that was just a miss-type on my part. Right now I have enough room for a good 2 or 3 fingers between the tires unloaded. Also, in the below picture you can see I have what I believe is called a torque plate on there, but it is backwards, so the cones point out, not in (where they would engage the wheel). I believe this is because of the aftermarket outer wheels. With this in mind, the second picture shows how many threads are showing even with that goofy setup (came that way, dont blame me). Bearing ALL of that in mind, if I remove the goofy torque plate and run lugs like the ones in the third picture, I should have plenty of thread engagement with a 1/4 or 1/2 spacer. I'm going to go get one or two of those lugs at advance today and see if they will even work, then get the spacers and see if I still have enough thread engagement and also how much room I have.
Keep in mind I rarely load this truck down with much weight, and I plan to install load leveling air bags before I do anyway which should help with fender rub.
Showing the goofy backwards torque plate:
Showing current thread engagement with the longest studs I could get (brand new when I did the brakes):
Finally, the lugs I'm gonna try (from Advance) both to get more thread engagement as well as to help center the outer aftermarket wheels:
