Where is the tank selector valve supposed to be?
R8rPhan
California
Mark
1973 (1979?)
C10 long bed (Frankenstein truck)
I am rewiring my 73 chevy c10..
Trying to add wiring so that I can install the other tank and get the dual tank setup working... The switch is in the dash, and I have the second tank, ready to install..
I'm told that the selector valve is missing.. all the plumbing is there, but no valve....
I have already run an extra fuel gauge wire to the location where the tank sending unit will be.. But I am assuming that I will also need to add wires for the selector valve once I purchase one...
How many wires does that valve need, and where is it physically located?
I'm guessing only 'one' wire? Is that correct? But where should I route it to?
Thanks,
Mark
:cheers:
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
It's a single-wire valve, and mine is located inside the passenger frame rail where the metal line begins that goes to the front of the truck.
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
Thanks,
Mark
:cheers:
The valve itself is in the frame right under the passenger side rear of the cab.
there is 2 wires from the dash switch to the valve then from the valve there will be a gas gauge wire going to the 2 tanks Dose your truck have fuel return lines from the fuel pump back to the tank ??? There is 2 deferent valves (1) with return line and (1) without a return line . the 1 with a return will work with either system just plug off the return nipples .
R8rPhan
California
Mark
1973 (1979?)
Found this for a 77!
attachment.php
jlyon1006
