Raider L
- Sep 1, 2020
- Shreveport, LA
- William
- C10
After doing some more reading about why my shifting is so early in my newly rebuilt TH350 trans. '74 C10, and I still haven't put my new 4 bbl. kick down bracket on the motor. Having a Holley carb. about where would the end of the kick down cable end look like at rest on the carb linkage when attached? All things being equal, and from all the photos I've looked at of both Holley's and Q-jet 4 bbl's. it looks like the end of the cable has about a 1/4" to a 1/2" of the end showing beyond the post of the linkage at rest, and would be the same with the engine at idle.
If the above statement is true and as the throttle linkage begins to move just of idle, as the linkage begins it's rearward travel and the throttle linkage closes up that bit of slack at the end of the kick down cable, that 1/4" or 1/2" end beyond the post, what is this movement of the kick down cable doing as the throttle linkage moves back, pulling the kick down cable forward? Is it, according to my recent reading that the kick down cable affects shifting early, is the kick down cable working in tandem with the governor? If not, then what is the kick down cable doing as the carb linkage moves, say to 1/3 to 1/2 throttle? What is happening as the truck is pulling up a moderate incline as like on a "on ramp" accelerating through 1st, then 2nd, and as the truck moves out onto interstate and at about 40 or 45 shifts to 3rd, what affected that shifting, the kick down cable's position pulled out by the carb linkage, or the governor according to engine rpm? Or both? Showing the relation between the kick down cable position at part throttle, and the governor/engine rpm, or neither of these and is just affected by the governor and the engine rpm?
Whew! I hope that's clear enough. I've thought about this long and hard to try and get it clear in my own mind as to what it is I'm trying to figure out. After I hook up my new kick down cable bracket what should I be looking for as far as shifting is concerned? Nothing, and I have a problem with the governor being out of calibration or something else, and it still needs to go back to the trans shop? Or since the kick down cable connection is corrected it will allow the trans to work like it has for the past 39 years like it always did and it will start shifting like it should with no further concern? It didn't start shifting like it is now after I put the 4 bbl. on, it shifted just like it always did even after that little link was installed. See below:
This little link, which is a Holley part, will be coming off and the end of the kick down cable will be attached to the carb linkage with the new kick down bracket relocating the cable end, where that hex bolt is, for a 4 bbl. is installed. Why would the trans still shift correct after a 4 bbl. was put on the engine, and shifted correctly for 25 years, but now that the trans has been overhauled the trans is shifting way to early. It shifts to 3rd at 20 mph no matter how much gas you give it, no matter where you are going up hill, and no matter how fast you accelerate. Since the trans has been overhauled, is it shifting to early because of this kick down set up? Or is it because of a problem with the governor, or whatever? Will the early shift go away when I change out the kick down bracket and move the kick down cable end to the carb linkage where it belongs? I just need some kind of idea of what to expect.
