Where does this hose hook up to?
SquareRoot
What wasn't working correctly after you drove it home from the shop? That will at least tell you where to look.
Jimmy84
Brownsburg, IN
Jeffrey
GMC k5
5.7l
It looks as if it's going through the firewall. If you had cruise control on that truck at one time, it could be the cruise control vacuum break that went to the brake pedal valve. Without having vacuum operated AC controls, the only other reason for a vacuum line that size to run inside your truck is for the cruise control vacuum break. On my 84 that hose goes through the driver side firewall to the lower right hand side of the master cylinder.
That’s why I’m thinking maybe a gauge
gmbellew
Kansas city
glen
suburban 1500
even non-AC trucks use vacuum to switch from floor to defrost, right? or do they use a cable like the hot/cold door?
Raider L
Shreveport, LA
William
@akchevrolet,
Did this shop put a oxygen sensor in the headers? Or a bung for one? Since you don't have A/C this line could go to some vacuum source, and the engine wasn't running funky coming home? Non a/c vehicles had a cable pull for the heater and vent door. And wires could have been in this hose since it's going into the cab, to protect them from engine heat.
Raider L
Shreveport, LA
William
Call that shop and ask them, "What the heck did you do to my truck??!!" lol
akchevrolet
Andrew
R10
Found the plug for the o2 sensor they didnt cut it. Didnt put a bung on the headers for the o2 sensor.
86 SCOTTSDALE
Oakham MA
Armand
No, Non AC trucks used cables, Bothe my trucks are non AC and I have removed the air plenum from bothe my trucks to clean out mice nests.
Dave M
Banned
Australia
Dave
Get your head/hand up under the dash and find where it goes to, simple.
Dave M
Banned
Australia
Dave
I was asking for the outside not inside.
Sure, but if you know exactly where it runs to, we can possibly better advise you as to where to connect it back up..
It may be a redundant hose.
akchevrolet
Andrew
R10
true true ill take a gander
GorillaHumper
