What should my new seat be????
Tackelbarry
N.C.
Scott
K25 Sierra
I have dual tanks so I am not looking to cut out or modify the floor pans. As long as they sit low enough I can easily build new brackets for them to attach to. Any idea if that would work with that style seat?
bluex
Spartanburg SC
C15
Would the 95-99 seat in the video work in a 1979 GMC K25 standard cab? If so, that is exactly what I am looking for. Thanks in advance.
Yes it will.
One note to add. The stock seat brackets are different between 73-80 and 81+. Whatever tracks your going to use get a matching set. I had one 81+ set and one 73-80. Made a little extra work for me to make the heights match. I also took the outer bracket that came on the 60 side and cut it up to make the front inner mounts that I welded to the floor. For the rear inners I welded a nut to a fender washer and then welded that to the underside of the floor.
Tackelbarry
N.C.
Scott
K25 Sierra
Looks great, thanks for the info. Actually, I will be looking for a nice looking set of blue seats like you pictured. Thanks again.
Tackelbarry
N.C.
Scott
K25 Sierra
I have been looking online but not having much luck finding a set. I will start calling local salvage yards tomorrow. Any other advice? Thanks again.
Wide_Nalgas
SoCal
ELi
C30
I just installed BMW 740i power adjustable seats! + 1990 Suburban center console
jlyon1006
