crazy4offroad
Equal Opportunity Destroyer
- Jul 30, 2010
- West BY-GOD Virginia
- Curt
- K-10
- 350/SM465/NP205
If you could get the spec sheet of the crate engine, that would help a lot. Compression ratio, cam specs, horsepower rating, anything you can find. Some of those engines I don't understand why they even produce them, the power numbers are a joke in a 5,000# truck. And a 2.5" exhaust on a weaker engine don't help performance, actually hurts it on the low end. Believe it or not but if you need more bottom end torque a 2" exhaust can get you there.
Try taking the flame tip off a propane torch, and put a section of vacuum hose on it. Start the truck and move the hose around the front and rear of the intake manifold, where those rubber gaskets go that most people throw away for just a big bead of silicone caulk. If the rpms spike, you have a vacuum leak.
Depending on the heads you're currently running, Vortec heads are bolt-on 40 horsepower, so they really are a worthy mod. They even outflow the best 2.02 old school casts right out of the box. Intake manifold compatibility is the reason most don't do it. You can mod your current manifold to work or drop about $160 for one made to adapt between L31 heads and carb.
And yes I saw you had a '79 but just felt there was something more, and admitting you're a F*rd man confirms lol. To crush a truck that has good parts on it even if you take the motor out tells me at least where your loyalty lies before you even said it. You could make more money on good parts than scrap steel (I know, I scrap a lot and it is way down right now) and it shows more of your frustration than anything. I didn't say you were being an ass, but more times than not I've passed on helping people who are down on their truck. Maybe that makes me an ass? Or a hypocrite because I've been there, quite recently really with my trans swap. But when seeking help I try real hard to control it. (coming from someone who has a terrible temper) Sometimes it just don't work out though lol.
