What rims with a 4/6 drop
Trick22
Enid,ok
Patrick
What size rims can I run with a 4/6 drop without any other mods
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Really depend on how you plan on doing the drop...spindles, springs, cut coils etc. Up front for example if you start with 3 inch drop spindles, the oem 15" rim wont clear the lower control arm. You will need to do a 2 inch drop spindle at the most, then a 2" drop coil. You should be able to use an oem 15" wheel, but with a much lower profile tire.
Trick22
Enid,ok
Patrick
It’s a 2 1/2 spindle drip with coils with a c notch and flip kit in the back.
thread moved to the proper subforum :waytogo:
Trick22
Enid,ok
Patrick
I ordered the kit from lmc
carlgm
Fl
Karl
'85
With 2.5 spindle drop, 15x7 wheels with 3.75" or 4" backspacing should fit fine.
jlyon1006
