CRM
Pasco, Washington
Casey
K2500
350 CI
Trying to remove 3 copper lines 1 at a time with a single tip is a lot of work, not to mention a lot of welding.
A sawzall will remove them all right quick :rofl:
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Alright I'll stop clogging up this thread after this lol. I wanted to clean and lube under the release valve knob, has a simple spring loaded dowel pin, ended up getting a little extra and cleaning it up all the way lol. It looks so much better. I also found out where the light switch mounted, it's on the left side handle, has some threads on the inside and what looks to be like what looks like the inside of a flashlight.
The only other things im gonna do for now is clean and flush the reservoir, and pressure wash the unit. I've also got some grease zerks for the rear casters.
I've also found some literature, this seems to be about all I could find. The lower pictures on the one sheet is stupid hard to read so I'll insert it. Has "lightening lift" lol I guess that's why it's only six pumps unloaded.
Pictures left to right-
1- (self aligning connecting rod)
- Longer life- Power unit is stationary, avoids wear as with moving power unit, auto-like, piston moves freely.
2- (only one exposed pump piston, for two pumps)
- One pump, two speeds- Exclusive, patented 2 speed pump encloses load pump, eliminates extra exposed plunger and parts.
3- Easy maintenance- Power unit is accessible for quick valve inspection and cleaning, simply unscrew cover plate.
4- Extra safety- Saftey control knob with positive lock, prevents tampering with release valve and accidental lowering.
5- Fingertip control- All controls are at top of enclosed handle, no footlevers or gadgets to accidentally trip.
6- Clogproof- Enclosed construction prevents dirt, water and grease from getting inside to clog power unit.
SDJunkMan
Black Hills of South Dakota
Jeff
Picked up a HF soda blaster and almost full 50lb bag of soda for $40 off Craigslist. They also threw in a new packnog nozzles and a nice pair of goggles. Only been used a couple of times. Not sure how useful it will be cleaning up the cab when I rebuild my 78, but figured it would be better in hard to reach places than a flap wheel, or doing it by hand. Anyone have any experience with one of these?
SDJunkMan
Jeff
Also picked up a new top box, although I have no idea where I am going to put it. My son was at Lowes and saw it marked down and called me. He got 2 of them (one for each of us) for $61 each! Regularly over $400. New and undamaged, we figured they changed them a little, so marked down the old ones. Guess I have to start looking for another bottom box. Still looking for a 10-12 drawer 27" wide Craftsman to go under my other top box.
Curt
Loco Hills
Curt
K-30
Got this crimper for the coming up rewire on my Chevy.It’s beefy and USA made.Nice quality and looks precision.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Looks nice. Will that do Weather Pack and Metri-Pack connectors that GM is so fond of?
Yes ma’am
that would be really handy lol
I Really want to get a crimping tool and a delphi metripack/weatherpack jumbo kit because I would be lying to say that I dont have any broken connector bodies, sketchy terminals etc on any of my vehicles lol. my alternator on my park avenue, for example, has a generic metripack connector spliced into the wires then connected but its cheap aluminum terminals which spread/got opened up on the first insertion, which is better than the original terminals out of the broken connector body of the original connector that were uninsulated and just grabbing the pins lol.
I wish I could buy ford sensors but with delphi connections because you see in the front of the valve cover i have a temp sensor with the wires in household push in connectors. The wires are so frail, the connector has a broken plastic spring retaining thing so it just pulls off, etc... but Ford wants oogles for their proprietary ****. not gonna get a motorcraft tool and terminals/bodies for ONE vehicle, even tho i would get to use it heavily.. lol
DanMcG
Central NY
k10 k10
Found a deal on a Awata lph400 so I grabbed it, now I just have to wait 3-4 months till it;s warm enough to use it.
Doppleganger
OH-MI: Just like it sounds
Putting in new counter tops and there isn't enough room to cut out the sink on the back side with a built in backsplash......so got one of these things only because some old timer on YT was using one to cut his sink out. UFB. Home Despot has a special going ATM....tool, charger and battery for $99. Thing is crazy handy. Oscillates so kind of buzzes. Sounds like Hendrix warming up for the Star Spangled Banner.
Doug Hampton
