What is this?
80BrownK10
Greenwood, SC
Nate
Or BMWs made here....Stihl chain saws made in Virginia Beach.
80BrownK10
Greenwood, SC
Nate
But in all seriousness, if you have experience with foreign stuff you should not have much trouble once you actually look at how it's all routed. It's no where near as complicated as those old Toyota's or Mitsubishi's I have worked on. There are vacuume lines everywhere. Even factory dead end lines that branch off of things. Some of that crap makes no sense to me??o_O
WesN
Edmonton Alberta Canada
Wes
C1500
It looks like your torque converter lockup vacuum switch located by the brake booster doesn’t have a vacuum line going to it.
Ugh... the very first engine removal I ever did was in high school on a 1991 Toyota Supra.. that thing must have had 100 vacuum lines all over the place. It was a fricking nightmare.
When you are doing 1 like that, unbolt the intake leave fuel lines and vacuum lines attached.Bungie it to the bottom of the hood or somewhere else out of the way. It's a huge time saver.
It's not really a viable way to do it. They don't go just to the intake and the hood has to come off to fit the motor in/out. Also, I had no real idea what I was doing at the time. Now I just tape each connection and label everything. Thankfully I haven't had to do one like that ever again. Motor swap in the K25 will have a single vacuum line for the AC system and either hydro-boost or the big vacuum line for the vacuum booster. Nice and simple
817esteban
