dariocortez
- Nov 26, 2023
- boise
- dario
- c10
- v6
I don’t think it is since I already have the oil pressure unit connected. It’s a brown wire I believeIs that wire for oil pressure/sending unit?
Wouldn't have anything to do with power issue but to me looks like oil pressure switch connector
Some accessories work, radio headlights etc. I haven’t checked if I have power to the ignition. I also replaced the neutral safety switch. I’m not sure if I’ve adjusted the ignition switchYou replaced the ignition switch, is it adjusted correctly?
Try starting it in neutral.
If that doesn’t work, make sure your foot is firmly on the brake, hold the key in the crank position, and slowly move the shifter thru the gears. If it cranks, the switch isn’t adjusted correctly.
Thanks! Just tried that and nothingTry starting it in neutral.
