- May 18, 2020
- Auburn, Washington
- Todd
- K20, C10
So couple of conflicting (it seems) experiences here. One would think under "light" use, the LPSV provides a somewhat reduced pressure from the master cyl (or is there a normal proportioning valve up front as well?). When the truck is loaded, the valve is rotated providing more/up to full pressure from the master cyl.
One person's experience is that the valve can keep the rear brakes from working and eliminating it puts it back to "normal."
Another's experience is that "normal" is with it working and when it sends full pressure, the brakes have too much pressure in the rear and lock up easily.
Leads me to believe that if the LPSV is eliminated that a different proportioning valve is needed up front to reduce rear brake pressure compared to front pressure? No?
Plenty to do and not messing with it in the near future unless I have to, but sounds like it will be going in the recycle bin when I have the opportunity!
It would be cool to get it functional if the truck was towing or hauling heavy, but I don't see that happening. Got a 1000 ft-lb coal roller for those jobs.
Thx for the input guys!
