what is that outer axle seal thing called
86chevyk20
Buffalo
Liam
im rebuiling my corp 10 bot.
When i replaced the u joints in my front axles that dust cover or seal that is on the end of the axle, it like butts up to the hub or somthing. they were ripped so i took them off.
My question is
what are those called so i can buy new ones.
Thanks
Swims350
Logan WV
none
try axle seal, hub seal or wheel seal, my advice and what I plan to do, run down to local chain parts store, like napa autozone oreily etc. have them look it up, match it up with what's left or wha looks to fit, buy that, or write down the number off their box, and find the same one from rockauto or somewhere cheaper.
Beatdown Z
Newark, DE
Go on rockauto, click on the drivetrain tab, and look at everything. It's there, I just dont know exactly what its called. Try spindle seal...
MrMarty51
Eastern Montana
Martin
http://www.oreillyauto.com/site/c/d...=Search_C0055_1052165_1466&pt=C0055&ppt=C0337
Thats the seal that goes into the end of the axle before the knuckle goes on.
Thats the seal that goes into the differential tube,before setting the ring gear carrier into the bearing stirrups and putting the U clamps around the carrier bearings.
The seal He`s looking for is made of a rubber like material,no steel,and seals the axle u joint yoke to the inner axle shaft guide torrington roller bearings.
gtewolf79
