What is stock ride height?
78C10BigTen
pennsylvannia
C10 BIG TEN
So the more i look at my truck the higher the back end looks. Its only 2wd but does this look stock or does anyone think my front coils are saggy? Also will 3/4 ton coils fit and how will it ride?
CSFJ
It's a big ten. They had heavier rear springs = higher rear end.
WFO
Texas Panhandle
I put front springs for a big block in my 84 GMC, to level it.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
As WFO suggested, this is the hot setup. There should be two versions, one with AC and without... it just handles and steers better with the front end picked up and don't worry about the spring rate being too stiff, it's perfect.
78C10BigTen
pennsylvannia
C10 BIG TEN
My dog was ac, when engine blew up ac never got put on the new one.one day ill rebuild her numbers matching 350 and shove it back in. With that "rake" im tempted to put a set of 50s on 10" rims out back
Craig 85
Nashville, TN
454/TH-400/NP205
I ran air bags in the front of a couple of my 2WD trucks to fit 33" tall tires. I ran the fill tubes through the upper holes in the front license plate. Gave me about 2" of lift. I ended up putting a 2" block in back to keep the natural rake. No ride issues, but my trucks had 454's with A/C. Here's the link:
https://www.airliftcompany.com/shop/60818/
78C10BigTen
pennsylvannia
C10 BIG TEN
Do they go in the middle of the coils
78C10BigTen
pennsylvannia
C10 BIG TEN
I just found that kit on autozone. For $100. But i think if im gunna separate the A frames ill just change coils lol then get crazy and add tubular A frames and new bushings and joints lol
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
that's going to get expensive for a daily driver.
zapattack
