Many lil items I've been collecting over years and some procrastination took over. Lil ice covered pass. side mirror started the decade long maintenance. It shattered from chipping ice off, cause De-Icer wasn't working fast enough for my freezing patience. Shudda just got heatgun out. A special order from autozone, flat glass no convex for me. Oh striker bushings, window seals, dr. window regulater after 20yrs of opening door at drive-thru lane, volt meter, hoping to make speaker selection soon, 6x9's or 8" woofer boxes behind seat? 6x9's in rear cab corners, with metal oval plates holding securely in place. Soon to tackle few oil leaks, side covers,valve cover. delay wiper switch, washer pump hot wire from new switch for activation. 10 Additional braided grounding wires from motor to body to frame to body. New 7 pin trailer plug, Electric trailer brake controller, grease n gear oil check, wally world charges you for it, but DOESN'T actually do it, on account of air lube gun is broken, going on 15 yrs ,so I was told by grease monkey. changing dark brownish brake fluid, another 25yr maintenance flaw on my character. Then main reason I'm here is for new idea or just better one for the cheap plastic glove box hinge, LMC only place at $30. Was thinking innertube rubber with short cable to keep door from putting bruises on passenger kneecaps...I'm open to anyone with better fix than GM had, third one to break on me in 25yr of SWB ownership. I will try to get some pics later today n posted. HAVE GREAT SB DAY. maybe its time for barefoot pedal n tiny foot dimmer cap install...still collecting pieces for 5.3 LS addition this winter
