HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
Dyed my new rear seat armrests and installed them. Not sure if I like the color; may re-dye them to more closely match the upholstery.
Looks like the third row seat in our '79 Burb. IIRC the various plastic pieces are slightly different shades anyway so it looks okay to my eyes.
Then again, that Burb was a bit of a Heinz 57 despite being only 10 years old when we bought it in 1989; had a GM Goodwrench 350 in it and various other not OEM bits. Even though it was a Silverado it had manual windows in the doors and manual locks. Power window in the tailgate though!
Put the frame on some tires so I can move it around. To prepare for the doner Blazer to come in the shop. Got some new bumper bolts from LMC. Started polishing them up.
Ajax19
Socal
Ajax
Finally got the bed cleaned out pretty good shape unfortunately no signs of the air cleaner so I'm going to grab one of those cheapo Edelbrock ones(I might have a OEM one I can rob off one of my other non runners) still no brakes but have everything but wheel cylinders should have it driving by next week
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
i moved mine 5' further into the garage so i could set up my wood shop haha.
Gearing up for the water pump/timing belt job on my 3rd gen 4runner.
pinballlarry1
Kalispell, Montana
Larry
250 6 cylinder
Had some time on a semi-sunny day, so I installed the aftermarket headlight-on warning buzzer kit from LMC truck. Happy with the results, not overly loud, but easy to hear.
This warning buzzer was an option according to the '81 owner's manual and the service book shows how it fits:
My fuseblock has the IGN and LPS plug in connections on the lower left, convenient to reach:
The buzzer kit is pretty generic for about $20 but has everything I needed. Basic 12-volt buzzers can be found pretty cheap.
Functions as intended, buzzes when lamps are "ON", and key is "OFF". I don't have any of the official chevy wire connectors that are keyed to plug into the fuse block, so I used the included brass adapters, they pushed in with a tiny flat blade screwdriver. I suppose I will start finding and stocking the official connectors. Self-stick pad holds it on the side.
Finished look:
K5 Blazer
Sant Cruz, CA
Holden
K5 Blazer
6.0L LS
Dropped my Blazer off at the Rear End shop after spending the last two years doing a frame off restoration including LS swap and new trans. The rear end gears 3.07 were way too tall after putting 33" tires and a 4L60E transmission. Can't wait to get her back.
brunoD
