HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
All the parts are on, only thing left to do is make all the lights work again, put the bumper on, and then I can finally turn some rubber down the road. Can't wait to get it all wrapped up
I love the late 50s tailgate! My dad's first pickup was a '56 GMC short bed stepside. He customized it, and put an aluminum cover over the logo though.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
Started engine assembly finally. Very glad I got a pushrod checker because the originals are too long for my application. On top of that, need to find a timing gear puller and need to figure out m cam button situation, as it isn't quite fitting into the cam gear. Or is it? As my brother has decided to start building an extension to the garage loft.
Shorty81
Baby Boomer
North West ohio
Darren
Wow, that turned out nice!!
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Plugged the heater hose outlet or inlet. Then filled it up and ran it up to 165. Then took it around the block to warm it up some more and see if it leaks after building pressure.
Question, why did it not build pressure? The top hose wasn't tight. No leaks as far as I could tell and temp was 190. Seems to run about 170 in town no getting on it. I left it running in the driveway to see any leaks. None and that's when it got to 190. Could easily squeeze top hose.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Wow!! @GMC_Nick Excellent work. Truck is looking sweeeeeeet dude! I hope you are glad you went out and did this.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
@82shortbed 190 is a normal temp while running. What is your concern? I may have missed a point you brought up...
Travlr
Central Utah
C
K20 Camper Special
Swapping bodies on the Chevy chassis has some challenges. I've already solved the saddle tank delete with a Blazer tank. Soon I'll have to figure out the radiator. In the meantime my gauges came in and this is the new set in the dash housing for the M37.
The speedo is a GPS unit so if I change gearing or tire size the speed indicated will be accurate.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
maybe your rad cap is junk
Johnny Atomic
Little Rock AR
Johnny
Sierra Classic 1500
‘85 Grille on an ‘84 ? Well why not… Still searching for that ‘83-‘84 GMC Grille ! Anyone? Anyone? Bueller?
You aren't the only one looking for that grill. Mine isn't noticeably broken, but does have a couple broken mounting tabs.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Just wondering why it never builds pressure. It's not running hot just does not build pressure in the top hose. No leaks as far as I know to relieve pressure. But I can squeeze top hose really easy.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
I see cap tester adapters for both sizes in there
mxer147
Colorado
Jack
k20
Squirted the top, interior tomorrow with orange. Amazingly only one bug found the sticky paint. Some orange peel but what can you expect painting outdoors at 55F.
Travlr
Central Utah
C
K20 Camper Special
I had a great day. Cutting and splicing the two cabs together for the body swap... and never really knowing if the vision was going to work as it seemed in my head. A week of work with no sure outcome... and the possibility of ruining the cab parts I need to have.
But today it all came together. The firewall fits, the floor will fit with a little tweaking, and the body mounts will be where they should be so the steering column, brake pedal, and accelerator all fit without having to be modified.
WHOOP, WHOOP!!!
BrianBaca
