Khayward
North Idaho
Kevin
Suburban SLE
Finally got around to registering the war wagon this week after a new fuel filter and making sure the 15 year old tires were properly inflated. It's on 31s so did the math and came up with 45psi. Front left was at 20.
Now it's road legal and already finding bits and pieces - missing when warm which might be related to hard starting; have to crank, let off, crank again and tap the throttle. I had planned on replacing fuel injectors next as they appear to be dribbly. Also need to go over vacuum line.
Steering is like herding cats. Almost an 1/8th of a turn of slop and wanders a lot.
Instrument lights disappeared.
Rear aux heater functions, but rear heater core has a tiny bit of coolant in one corner and the hoses to the valve under the hood seem to leak at the fittings.
All small stuff, and it's fun to hear the straight pipes sing :)
1STLS1
West Phoenix AZ
MIchael
The wheels I sent out for restoration and repair finally came back and overall, very happy with the results. Cleaned then powder coated gray, then the raised portions have a brushed finish. I had asked for machined like factory but the restoration place said it doesn't come out as well on older wheels as the brushed, it ends up with pits from the pores in the casting. They fitted steel inserts to use a conical lug nut compared to the original shanked ones which always came loose and elongated the holes. Tires and centers are ordered.
Ordered a complete weatherstrip kit and new window regulators from Rock Auto in order to just do that once and not fight it.
Threw the oil pan back on yesterday with a fresh Mahle gasket and plenty of Permatex. This SOB better not leak this time.
Then pulled the tank down last night right before I left. Gonna throw a fresh Walboro in it. This makes the 5th fuel pump in this truck :hidesbehindsofa:
Those wheels are FKN SWEET!!!!! Fk me I'm so jelly!!!
Memaloose
Dolan Springs, AZ
Tony
Mine was just basic maintenance. I just replaced the original fuel hoses on the fuel pump, 47 years of service. Thought I had a coolant leak when I looked under the front end but popped the hood and there was fuel pumping out. Good thing I wasn't out off roading.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Damn... 5 fuel pumps?
Yep. The first three were killed by a faulty plastic sock insert on the sending unit coming apart and sending shrapnel into it. The fourth one that's in there currently was struggling against a pinched line that I didn't find until about 6mo ago so I ordered a Walboro 255 and it's been sitting on the shelf ever since. Since we're fixing to go 4000+mi in the next 2 weeks, I didn't wanna chance a tired pump. Hopefully it'll be the last one
1STLS1
West Phoenix AZ
MIchael
I was surfing Ebay and came across them, made an offer and the guy accepted. When they showed up, 2 of the wheels were damaged in the lug area, one of them wouldn't even center on the hub. Even though 2 were scrap at this point, at least I had all 4. There are pairs and "3 of them" for sale all the time, getting all 4 matching is impossible. Spent a hour or two researching what to do, called a couple places, finally found one that knew what it was and had performed similar repairs in the past. I may have to install longer wheel studs and the wheels scraped the caliper bracket so need to do some grinding on it but overall happy how they turned out. His price was more than fair but all the shipping made it expensive
https://jasonswheelrepair.com/index.html
CRM
Pasco, Washington
Casey
K2500
350 CI
Finished installing the new wheel well trim. Loooks a lot better. I was going to check the timing but I couldn't locate the timing marks on this 350. Any one have a picture of the location?
Its either 2 or 12 o'clock on the harmonic balancer. If it isn't there, you could have an aftermarket cover that someone didn't put a timing pointer on.
CRM
Pasco, Washington
Casey
K2500
350 CI
Found it. It sits at 12 o'clock, under and behind the water pump. This is not going to be easy to check timing. My only question is what is the round thing,that looks like it holds a pencil, for?
CalSgt
CA
Casey
Huh? I don't see what you're talking about
CRM
Pasco, Washington
Casey
K2500
350 CI
It's a round cylinder mounted to the end of the timing plate.
CalSgt
CA
Casey
Google had the answer, from a different forum where several people asked the same question:
"Yes, back in the day my "Allen Smart Scope" had a magnetic timing probe. It was a flexible wand style attachment for the Analyzer that allowed you to keep constant digital readings on the scope at all times. The great advantage was you could be adjusting and monitoring other settings without having to hold a timing light. Suppose to be the wave of the future.
It came along during the first years of "CCC" or "Computer Command Control" for you young folks. It had to be set into the Analyzer with a 10 degree offset setting so it could reference TDC.
These were some horrible years for GM and its electronic controlled carburetors, when fuel injection and OBD 1 and OBD 2 came along all this stuff went away.
Sorry for the long post but I thought some might be interested...."
I also found this image:
Otherwise ignore it.
full
2manysquares2care
