hoagster
California
K10, 1500
5.3l
Found A pair of Custom||10 fender badges, so I can restore mine or should I say play with the originals?
Here's the OEM, as you can see there is a part number on the back, do a search and Classic Ind. has them is stock!
Mine look good but I want to change up a bit. the yellow inner portion of the numbers is going Fairway green! If I mess it up these originals get cleaned up and installed!
waterpirate
delaware
v10
5.7 tbi
Okey doke, no problem. Everything off that one fender, or both? And is that an acceptable year?
Just that one fender. I am no expert on the yearly changes, but looking at the pic I can make that work. The truck is not going to be a trailer queen when finished or judged. I just want to get the factory stuff re installed the best I can.
Blmpkn
Maine
Will
Got the front clip all unbolted yesterday in preparation for its squircle conversion, and scored an oem 73 gmc grille on ebay in acceptable condition for the end goal of the truck.
Just need the core support to arrive... then buy lights, bezels, and year appropriate hood latch goodies.
AAAAH! getting close!
They all landed at Mt. Shasta the other day
Those lenticular clouds formed over the tops of mountains like that are a sure sign that it is some nasty mountain wave wind patterns happening up there. It's one of the major signs pilots use to know to stay the heck away from the mountains. You'll get wild 5,000-10,000+ fpm downdrafts on the leeward side of the mountain as well as some wild turbulence sometimes. The downdrafts are a killer though as even at a max throttle climb it will slam the plane right into the ground.
We get them forming quite a bit over Mt Hood and Mt Rainier on windy days.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Put the dash back together as I had to do more instrument cluster bulb work.
New parts on order, so if this does not hold backup is on the way!
On my phone, so not sure how to put text between photos.
So :
The carton pic is my dash screw memory aid. :anitoof:
Then the amazing radio mount - ugh.
Getting pretty good at getting it apart.
Then the fix.
Then, look Ma, it works!
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
new seats, new retro sound radio whit 4 new Kicker/Fosgate speakers and Brother 6x9 rear bracket and under seat Sub! :)
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
Those corner boxes are nice looking!
thx after a long search and comparaison between 2 model... i choose the one that get a full encloser for a better deep sound quality ;)
CRM
Pasco, Washington
Casey
K2500
350 CI
New spark plugs and wires, new oil and filter, and finally adjusted the valves. All but 3 were sloppy. It was interesting how much old gasket material was in the area around the oil drains. I was going to replace the valve cover (250 straight 6) but for the life of me I couldn't find an 11 bolt valve cover anywhere online. Guess I'll go with RTV instead of a Fel Pro.
thatgermanguy
