Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Nice work! Those brakes will last a good long time. While I enjoy the utter simplicity of disk brakes, the old 3/4 and 1 ton drums have some serious stopping power.
An aside, I knew the brakes worked really well on the blue truck when we bought it last year. Could see new calipers up front and the drums looked clean on the outside and spied new Nails in the backing plates. Presumed someone at least put new pads on.
To my surprise and pleasure, finally popped the rear wheels off a couple months ago when I was painting the chassis, and the back brakes looked identical to your pic, save for a very small amount of brake dust. Everything was new, right down to the springs and hardware. Drums slid right off with just a little wiggle. (Sf axle)
People rag on drum brakes on cars, probably all from bad experience with unassisted systems on older cars. Most people don't realize that big trucks are primarily equipped with drum brakes and they provide plenty of stopping power for a lot of weight. Biggest thing is proper adjustment, and on our trucks the use of heavy duty shoes. They'll last a seriously long time. I usually get around 100K out of a set vs about 30-40K out of organic shoes.
JeffK10America
Easley sc
Jeff
Finished up some frame painting on the frame , installed my rear shocks . Replaced my rear brake lines , with SS
Next run the rest up toward the front . That should be fun . Got them from U line
FranticMeeping
Minnesota
6.2 Diesel
Finally got an hour to spend on my truck. Got the front wheels off, and started replacing the ball joints, drag link and tie rod ends. Didn’t realize how wore out they actually were. Should handle like a new one when I’m done
I ordered the Kilmat from Amazon. They have 2 thicknesses. 50 or 80 mil.
I got the 50, but had enough extra & some of another brand to double up a few places and put some in the doors.
A box (47 sheets) will do a standard cab 1 time.
@hoagster I also got the Killmat for sound deadening from amazon, but also got a closed cell foam layer to go over the top of that for added insulation. Both were ordered on amazon for a total of about $150 to have enough for the entire cab of my truck and probably most of my commuter car as well. I'll likely need another set of killmat for the other car, but the insulation roll is enough for 100sq. ft, which should be plenty for both cars.
https://www.amazon.com/gp/product/B0751G6TMV/
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I degressed and pressure washed my engine before I start tearing it down.
Smart man. You have no idea how many people I see tear into a snotty POS with all kinds of road grit and slime on it. It not only makes them gross to work on, it pretty much guarantees you're going to contaminate the job. Someone pre-cleaning is the exception when it should be the rule.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Smart man. You have no idea how many people I see tear into a snotty POS with all kinds of road grit and slime on it. It hot only makes them gross to work on, it pretty much guarantees you're going to contaminate the job. Someone pre-cleaning is the exception when it should be the rule.
Thank you sir.
Yeah, that thing was such a little ball of grime, I was going to risk getting that on the inside. Makes it way easier to work on too.
Cleaned it more after that pic, used a scraper knife and some foamy degreaser. Down to the original paint again.
When I'm done, I'm gonna paint it a nice Chevy orange.
Started tearing it down a bit more before I had to leave.
Want it look like this
78C10BigTen
pennsylvannia
C10 BIG TEN
More stuff that I'm hysterical about but is old hat to you guys. I haven't done drum brakes since the Fall of 1987 (no joke). Took me about 3+ hrs over 2 days but figured it out. They'll never look like this again. All new parking brake cables as well.
Which means I could put the drums on and mount the rear wheels again. Finally cookin with gas. Next up is the drive train. Woohoo!
Fall of 87' you say.... i was only a few months old! :happy175:
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Motor and trans are in. Boo-yah!
Accessories, FI and headers are next up.
That's looking good. Super clean.
I didn't know they made 8 bolt American racing spun aluminium mags.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Got the heads, intake, valve covers on another one of my projects.
GorillaHumper
