78C10BigTen
pennsylvannia
C10 BIG TEN
Not my square but my baby square (s10) i just did new spark plugs and oil change. Used ac delco copper plugs and castrol gtx HM 10w-40, a can of restore and yes a fram filter.
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
I didn't do it but new exhaust finally!
MY GAWD THAT'S NICE!!!!!
80BrownK10
Greenwood, SC
Nate
Having done this a few times, best advice I can offer is using some glass cleaner spray-foam to help lubricate the channel runs to accept the felts. By rear seal, is that the rear channel run for the glass ? If so, it’s way easier if you remove the guides lower bolt and loosen the guides top bolt on the jamb.
And take the door panel off so you can reach in there.
80BrownK10
Greenwood, SC
Nate
I didn’t know I was “colorblind” until they gave me an Ishihara dot test at MEPs. Didn’t see many numbers pop out. Weird thing is I can distinguish colors accurately in real world applications. I have a buddy I work with that’s always screwing up color coded wiring. He’s seriously deficient. I have to come in and fix his wiring faux pas regularly.
Thats how I am with that book
TX87R10
Txr10
It was actually nice today temp wise and someone caught me blasting the back of the cab. Should be done with that tomorrow!
This is looking great just went all the way back from beginning of your build thread, really cool stuff.
Question on your sand blasting - last time I tried that indoors it was an unbelievable mess to do, is there anything you are doing outdoors to reduce the debris or reclaim the sand or the impact of the black sand isn't much worse than normal sand? And have any issues with warping from the heat?
TX87R10
Txr10
This was 100% necessary for me. On both the driver and passenger side the vent channel all the way to the bottom was frozen in there and had to be scraped out. I did not take off the adhesive strip to seal it in to the channel yet because I think I'm going to pull both again this weekend and try to clean them even better as both windows move much slower now. I feel like I left some small pieces in there that are pinching the window.
Poppy 87
Bloomingdale GA
R10 Silverado
Glad to see you got the rona mask on too!
Sent from my XT1254 using Tapatalk
hoagster
California
K10, 1500
5.3l
That rona mask is to save the face from getting blasted that coal slag hurts, plus its coal so I had another mask under the stretchy one.
Poppy 87
Bloomingdale GA
R10 Silverado
I was just messing with you! That coal slag appears to work well. Is that a common blast media?
mrburitto
Casa Grande, AZ
Cody
K20 Cheyenne Camper Special, C30 Crew Cab Dualy
Just got my new wheels and tires put on :D
I went 35 BFG AT's. Not sure if im happy with the backspacing on the wheels though.
Is that lifted at all? Mine is almost identical, 1980 K25 on BFG 35x12.5... no lift but the front fenders were cut by a PO and so it clears.
mrburitto
Casa Grande, AZ
Cody
Ya I have a 4 inch lift. Mine were cut by PO to fit 33's but Im gonna have to cut some more. It tore up my inside fender when I went through a ditch with the wheel turned.
Doug Hampton
