82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Few more plus the video of the gauge.
I'm just guessing but, I think it jumps like that because of the mechanical pump. An electric pump would be a smoother more constant pressure. If that makes sense.
78C10BigTen
pennsylvannia
C10 BIG TEN
After swapping pumps it runs a smooth 9 psi but still no fuel in the filter and no squirts like if its pumping it.
Poppy 87
Bloomingdale GA
R10 Silverado
9 psi seems too high for carburetor engine. Usually see gauge and regulator plumbed after the filter. Engine runs?
Sent from my XT1254 using Tapatalk
78C10BigTen
pennsylvannia
C10 BIG TEN
Yup. Drive it daily. Thats why im confused why the filters empty but still runnin and drivin
ajd89
Central Michigan
andrew
Its in and runs! Would have been sooner if the weather had been nicer this week. Cab floor is all wet had to change a heater hose dont think its that. I think ill be changing my heater core. Cant win lol. We lost power today too so I thought id fire up the jenny since it dont run much. That didnt go well either. Just glad I seen all the smoke in time. After you check the oil good idea to get the cap on good and tight I guess.
Poppy 87
Bloomingdale GA
R10 Silverado
Are you sure that the filter is empty and not totally full? Install your guage between the filter and carburetor and report the results
78C10BigTen
pennsylvannia
C10 BIG TEN
100% sure. I can see just a trickle in the bottom at the inlet side
82sbshortbed
Fuckemall!!
SE Texas
Doug
This made me curuios so i looked at mine. The one going to the carb is pretty much empty.
The one before the pump is pretty much full.
82sbshortbed
Fuckemall!!
SE Texas
Doug
I fired it up and it didn't really get any fuller. It's a new pump too.
Even reved it a couple of times.
78C10BigTen
pennsylvannia
C10 BIG TEN
I dont have one before the pump
Turbo4whl
Downingtown, PA
Wayne
The hose on your lower filter has a crack forming. Imported junk that they sell us now. Maybe this whole Ronia thing will bring back more manufacturing to this country.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Well this was actually last weekend but i been havin phone issues so i never got it posted. Started out by noticing no fuel in my filter with the truck runnin so i bought another fuel pump. I added a pressure gauge in line with my old pump and holy cow was it wildly erratic! So i commenced to putting on a new pump and inspecting the push rod. I messed up the plate gasket and didnt have another so i improvised! Got everythin all back together and it runs 9psi but still no fuel in the filter and seems to not pump it up there. Im lost because i drive it daily this way with no issue, hows that possible?!
Nice improvise !
:waytogo:
goodwrenchca
