What calipers are you using for the rear conversion?
Sent from my XT1254 using Tapatalk
Caddy calipers with E-brake
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Swapped on the rallies. Thinking I like these better than the polished torque thrusts
Sent from my iPhone using Tapatalk Pro
Those are damn clean ralleyes!
Haha I wish they were that clean. Guy I bought them from just sprayed right over all the crap that was in them from sitting outside. I’m going to blast them and probably get the rears widened and refinish them
Poppy 87
Bloomingdale GA
R10 Silverado
Love that stance. What type of drop on your truck?
Thanks man. It’s roughly a 4/6. Thinking about dropping the front a touch more, might go to a 5/7
FireTruck1984
Michigan
Ted
1984 and 1984
Yes, the rallys look great ! Here’s a cool little trick, change the hex bolts on the center caps to polished stainless
legopnuematic
Licensed Junk Dealer
MO
Spencer
My Hella lights arrived so I got them on the 76. Still need to get the switch wired up, waiting for my wideband to arrive so I can make a new switch/gauge panels for everything.
Sent from my Moto Z (2) using Tapatalk
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Put my summer boots on, they look small for the truck to me. Really need to wear through these quickly, as well as the MT winter set so I can justify new tires.
Time for many burnouts! :burnout::burnout::burnout:
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Well this was actually last weekend but i been havin phone issues so i never got it posted. Started out by noticing no fuel in my filter with the truck runnin so i bought another fuel pump. I added a pressure gauge in line with my old pump and holy cow was it wildly erratic! So i commenced to putting on a new pump and inspecting the push rod. I messed up the plate gasket and didnt have another so i improvised! Got everythin all back together and it runs 9psi but still no fuel in the filter and seems to not pump it up there. Im lost because i drive it daily this way with no issue, hows that possible?!
I'm a "think outside the box kind of guy". So is the filter empty or completely full?
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
I'm just guessing but, I think it jumps like that because of the mechanical pump. An electric pump would be a smoother more constant pressure. If that makes sense.
That gauge is getting a workout, that's for sure
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Almost 99% sure its just a trickle. If its "pumping" i should see steady consistent squirts into the filter... correct??
Not necessarily. Once the line is pressurized it's going to be full and the pump will keep it full even under load. And with that filter being clear, it may just appear empty.
ExtraZ
