Kyle Childress
Brownsville KY
Kyle
K20 silverado
swapped out the IMCA single plane for a new Holley intake..... runs worlds better than the old single plane.
78C10BigTen
pennsylvannia
C10 BIG TEN
Lookin mean
73c20jim
Tombstone, AZ
With those rockers you should have a see thru valve cover.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Found a spotlight to tote around in my squares.
Sent from my Moto Z (2) using Tapatalk
Have her a quick detail job and got her out a bit this weekend :love62:
roundhouse
atlanta ga
justin
77,78,79,80 ?
I predict you will soon have a melted seat cover.....
When you turn it off
Unplug it
Took the '77 out on the town last night with the wife on a date. Kiddos were at in-laws and it was a beautiful night!
legopnuematic
MO
Spencer
Unplug it
I always unplug cigarette lighter stuff, I don't trust anything being left plugged in, for either if it drains the battery or catches fire.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
No pics, but put in a 180 thermostat last night.
We will see if it makes a difference.
195 was in it - OE = unknown, but probably.
Not in it today and will probably get home too late today to shuffle vehicles so Friday will be the shake down cruise !:D
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Here is the bulb I was talking about - I have had several of these trucks and just don't remember that one...
Underneath the ashtray.
My 74 came with one.
78C10BigTen
pennsylvannia
C10 BIG TEN
Took my wheel off and re-oriented it and drilled a new hole so i could access the horn button. Hit the wire to the center and the horn works. Hopefully soon i can get the horn button setup and put the center on it.
Later found out that the orientation was off to the right about half a turn... pissed me off so i pulled it off and re drilled another hole and put it right. So my wheel is fulla holes but hopefully the horn setup will cover it.
Jcarrasco314
