Clutch
Dirty Jersey
K30 Silverado crew cab dually
L82 350
Got my fenderwell toolbox complete enough to use, still have to paint and weatherstrip it. And fill it with tools...
Sent from my Moto Z (2) using Tapatalk
Nice job looks good
Kyle Childress
Brownsville KY
Kyle
K20 silverado
Got the dog house back on, not done aligning everything. Also my new grant steering wheel in it, the bow tie is crooked on my horn button.... Maybe I can hear it up with a heat gun and move it?
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Finally worked out the electrical/start issue on my 84.
After replacing the starter, cables, battery, alternator........damn igntion switch!!
Just out of mere curiosity, I tore iinto the old ignition switch and wallah!! Burnt and worn contacts. Go figure a $13 part was the problem.
silverscottsk10
trafalgar indiana
mike
Making progress on the 250$ 350, recent rebuild, they cant tighten gasket bolts though, all connecting rod bolts are torqued, as well as main caps, cylinders are clean as well as pistons from what I can see, getting new external gaskets and a paint job, stealing parts from my 350 that needs cylinders machined since that will be awhile, then hopefully will be going in the 85 in the next month or so just so it moves out of my way of my garage
Sent from my SM-N950U using Tapatalk
Kyle Childress
Brownsville KY
Kyle
K20 silverado
EFI................ going to start it this afternoon for the first time. Also, new inner fenders in.
silverscottsk10
trafalgar indiana
mike
Got a few goodies for the 350 this morning, just over 350$ into it
silverscottsk10
trafalgar indiana
mike
Oil pan I bought is a driver side dipstick, my engine is a passenger side ‍♂️
Didnt even consider it, so I'll be on the hunt for another now, I did however start a little sanding on the 80, and removed the bumper for not and leaving the new one off until I get the truck primed all one color
Kyle Childress
Brownsville KY
Kyle
K20 silverado
Got it running with the Terminator EFI, the video is after my cam break in.
Crispy
Carbon County, Pennsyltucky
Suburban V1500
Havent driven it in a while and come outside to see a pool of tranny fluid on the ground. How does that happen?
Looked under and cant pinpoint where the leak came from since its apparently self lubricating under there.
Kyle Childress
Brownsville KY
Kyle
K20 silverado
Its just GMs patented rust preventative program on all 25yr or older vehicles. When the highly sophisticated engineered seals on mechanical components detect the vehicle is immobile for a short period of time it triggers a leak of various fluids to address possible corrosion issues the under carriage may incur.
Big Chip
Michigan
Kevin
C35
Are you saying the last thing you’ve done to your’s is to curse it??
Crispy
Suburban V1500
I wonder if Chrysler copied the design. My 99 Cherokee had a self lubricating chassis also lol.
kobedemello
