Dallas, TX
Thomas
C10 Stepside
250 Inline 6
I just swapped the '79 grille on my Stepside to a '73 a few weeks ago. Right now it is only held in by the upper and lower center screws, still need to fabricate the side mounts, that's really the only challenge
Camar068
Kentucky
10 yrs Air Force
put the hood back on it so I can drive it to work after 6 weeks with the LS swap. It was 7pm when I was done puting up the tools. I sat on my butt for a bit on the computer. Come 8pm I had to get up and do something. Glad it wasn't the swap, ended up yanking the deck off the John Deere and cleaned up up....lawn looks like a damn race track with lanes.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
How did you pull that off? I tried in my 78 but the center support and all stick out to far to put it in.
Dallas, TX
Thomas
C10 Stepside
250 Inline 6
Oh sorry, yeah, you need the '73 grill center support when you get the grill also. The center one is removable but the two on either side are welded. Yeah, it is a tough part to find.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
I have a whole 73 for parts but the thing is rust.... its been parked since 05' so idk if the nose is still saveable but damn im gunna try.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Sorry for the thread derailment everyone...
Dallas, TX
Thomas
C10 Stepside
250 Inline 6
That small center bracket is all you need, just a few bolts and easy to get to. Good luck!
Back to the thread topic, I picked up a detent cable hold down screw at the hardware store, this is the one thing that went down without issue. Then hunted down a detent cable seal from NAPA which was too big and the only one they had listed. I had already set up a meet with a cool trans shop to pick up a detent cable actuator rod (that's in the pan) since that's not an auto parts store part so I asked him if he had a seal too and he did and it was the right one. It's a good time as any to crater a good afternoon so as I walked out to my car, the rod fell out of my wallet that I carefully placed there to be secure and I didn't realize it until I got home 20 min later UGH... I drove all the way back up there and found it sitting in the parking lot. alas, it was a wasted trip anyway because it was the wrong one too and was too long. (YES I know what a TH350 is). I tried to fabricate a shorter one out of it and did ok but it kept getting hung up and I didn't want to risk it so I said to hell with the auto kickdown, most of my cars when I was young never had them hooked up. So I installed it with the new correct seal and just left it not hooked up in the pan and finally I was ready to start it up. Put 4 Qt of tranny fluid just to start with until the converter filled up and of course the pan gasket leaks. I tightened it a bit more but it was a no go. It's a rubber gasket which I hate so I am picking up a cork one tomorrow, I knew I should have just replaced it from the get go but it was new and already there.
At any rate, I DID get to hear the starter engage the new flexplate and it sounds good and with the engine running I verified there were no "other" leaks so at least I kinda sorta got something accomplished. Tomorrow will be a standard pan gasket replacement.
silverscottsk10
trafalgar indiana
mike
Was gonna swap the torque converters, hit a small bump though, guess it calls for a nylock nut and thread lock to prevent coming loose since it'll be bolted together instead of threaded into the tc?
Sent from my SM-N950U using Tapatalk
Camar068
Kentucky
10 yrs Air Force
Looks like I'll be changing the steering box quick. Noticed a pool of something below the rear drivers side fender. Power steering fluid was coating the rear of the inner fender. Looks to be leaking from the output shaft of the box, and the box moves when I turn the wheel. Think it's still under warranty with Autozone.
Guess I didn't tighten down those bolts good enough when I hooked up the ORD steering brace.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Just finished replacing the speedo cable to no avail the speedo still dont work and im lost... also just put new metal center caps on that i got from the u pullit today. Way better then the old ones.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Wow the rust just sets them off..........LMMFAO jk dont cry just have a cigar and go to your happy place. Are ya still glad I’m back?????
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Lmfao!!!! I had many cigars today and cruisin my rusty square is my happy place. Its more comical with you here...
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Btw they will be sandblasted and repainted eventually....
Burbinator86
