Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
First go around was 2 broken springs, this time so far every push rod on ps side is bent this being the worst. Havent pulled ds yet. So whats your thoughts on dropping in 180k mi big block in?
Yeah something in the geometry is out of whack. These are Vortecs right? If so you have self aligning rockers right?
4WDKC
Southern Florida
Kacy
yes vortecs and yes self aligning, should note some of the dampeners int the springs i pulled out were broke.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Could you be possibly running to much lift for the Vortec springs and binding the coils and that’s why it’s braking them and bending push rods? Have you looked at the piston tops to see if they are hitting the valves?
Well, I really screwed up. Put in roller lifters on a solid lifter cam. This is #8 exhaust lobe
And here's #8 Intake lobe (in my previous post, this is the one with the lifter that was turned sideways)
The rest of the lobes are pretty ok but I'm pretty depressed. I was trying to make life easier on her and I've done some bad damage....le sigh.
So do you think that's mostly from the broken link bar, or that lobe damage broke the link bar?
4WDKC
Southern Florida
Kacy
its this cam http://www.pbm-erson.com/Catalog/PBM/Camshafts_PBM/Performance_CPBM/ERSE110026
these springs are what I just bought http://www.pbm-erson.com/Catalog/Erson/Valve Springs/PBM3000
with my amateur tools I measured .040" in the hole from the deck to the dished part, not the valve recesses, and not the highest portion of the piston. and gaskets were .039" thickness I believe.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Ok in stock form the heads won’t handle the .465 lift. If you had the guides cut down they would be ok. How do the valve seals look when you replace the springs? More then likely the tops of them are crushed. Are you running 1.5 rockers?
4WDKC
Southern Florida
Kacy
I had the heads set up originally to work with a 95 LT1 cam, the guy that set them up, decked to make flat, checked for cracks valve job new seats and said they were good for up to .510 lift cams. Then the springs broke.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
That just looks like conflicting clearances to me. Could you have gotten 1.6 rockers instead of 1.5s you ordered or are they stock? I know I’m asking a **** load of questions, just trying to help sort this out.
4WDKC
Southern Florida
Kacy
Stock rockers, only thing I can think of the dampeners were binding because they were catching on the perch and not all the way down, then broken pieces got caught in the springs.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Very possible. Do you have new ones with out the dampeners?
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Flat tappet cams are ground with a slight taper across the lobe that causes the lifter to rotate. This would make a roller load unevenly and unfortunately make it try to rotate.
Right, but would that be able to generate enough force to brake the link bar?
I always thought the biggest reason it was a no-no was because of the lobe profile. Because of the round lifter bottom (roller) it took a lobe with a wider profile to get a comparable duration and lift figure.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I don’t see it being enough force to snap the link.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
We haven't seen the lifter yet, but I would guess the uneven loading caused the roller or/and cam to fail first which led to it turning.
smorris
