donmateo
WI
Installed LEDs into the 91' Burb cluster I put in my 88' for my LS swap.
attachment.php
attachment.php
That looks great! How long did it take?
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I already had the cluster out to do wiring and etc, so it was really easy. Otherwise, it's just a matter of removing the dash pad and bezel, and installing the new bases and bulbs into the cluster. Really easy to do.
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
flip kit and bed change
took of the bed and did a 6 in flip and put the dually bed on and I like it
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
2" lift. Moved up to 33" tires.
silverscottsk10
trafalgar indiana
mike
Moved it to my house finally, getting ready to remove the 350 and rebuild it, how would the best way to drain coolant be? I'm trying to keep it from getting all over the driveway
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
I've always used a piece of fuel or vacuum hose on the radiator petcock into some jugs.
SlickGTP
Houston, TX
Finally got around to diagnosing an issue the ol' girl had with surging, backfiring, and generally just not running right.
Turns out she just needed a really good tune up for the most part. :)
87ChevyR10
Kansas
NA
NA
NA
What a day! All I wanted to do was get #6 and 8 spark plugs replaced and change the oil. I spent roughly 5 hours doing just that. As suggested, I went to a parts store to get an offset box-end wrench. Well, AZ had them as a set, but not individually. So, I went to a local tool store and found what I thought I needed. Spent $20 for a 5/8 x 11/16 offset wrench. Well, that didn't help me at all with #6. I finally got the bugger with a 5/8 socket and 3/4" wrench.
Next, I tackled the oil change. Getting the drain plug loose was a pain. Finally got it and let the oil drain before unscrewing the filter. So, here comes the part where I spent the rest of my day driving back and forth from various stores. There's not enough space to get a tradition filter wrench with long tube headers. Back to AZ I went to get a cap socket. Got back home, got the filter old filter off and started with a new K&N HP-3002 oil filter. Well, guess what, it's too damn long! The headers are in just the right spot to prevent that filter from screwing on. So, back to the parts store. Of course, no one knew which shorty filter I needed (my fault for not doing the research before hand). So, one of the salesman suggested I use a filter meant for a P/U with 4WD. It was still long, but skinnier. Took it home and it fit fine, but it would not thread on. Plus, the mouth wasn't large enough. In the past, I had my local Wal-Mart do my oil changes and they been using a shorty Fram filter. AZ didn't carry it and Wal-Mart did, but only in their shop. They wouldn't sell it to me unless I had my truck there for an oil change. Luckily, my Dad had his smart phone with him and a quick search revealed exactly what I needed. Bought a Fram PH30 and headed home. About half an hour later, truck had new oil and filter installed. SHEESH!
Anyways, FRAM is getting used this time. I need to figure out which K&N filter I can use. The HP-3002 would have worked with shorty or stock headers. I did see where an AC-Delco 454 filter would work, but I can't seem to find it locally.
I do have a question about oil color. It seemed to have a reddish-brown color to it. I have been using Castrol GTX High Mileage 10w40 oil since I bought the truck (except for 1 time) or that's what I've been using at Wal-Mart. Anyone seen reddish-brown oil before? Engine coolant is the green stuff and I know it wasn't ATF, no drain plug for that.
silverscottsk10
trafalgar indiana
mike
I think the edelbrock ran a little lean
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
Upgraded to the longer radiator today:
74 Shortbed
Looks good..
r67northern
Louisiana
Leland
Suburban r20
Agreed, looks really good. Nice install, is that a different top hose or did the older one stretch?
brentjo
