- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
Does blowing up the transmission count?
Apparently there were more problems in the transmission then just a bound up governor. Took the truck up on the freeway and the trans went South on me. Had to limp it home in first gear at 5 MPH.
What trans is in it??? Did you try to shift it manually? Did you try to get the RPMs way up high in 1st, then let off the gas and put it in D? If so, that's a way to skip 2nd gear if you trashed the outer intermediate race and roller clutch. At least gets you home in 3rd gear. That's if it's a Th350.
