Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
3 weeka ago, (on tbe burb), i Pulled a 3hr vacuum on my system, did a 1 hour leakdown test... seemed ok...
Last year i did a total overhaul on the system, but it all leaked from the compressor.....?
This time, i added a can of that mechanic in a can stop leak to the system, as well as however many cans until i saw an agreeable high and low side pressures i liked.
Drove the burb 4 hours to SC last saturday , ac pumping icey the whole time, and cruising around in the sweltering heat..... she stayed cold inside the entire time (front and rear ac)
Drove her back yesterday, again no issues.
*knock on wood* that 30 year old truck made it further than some of the shitbox broke down trucks i passed on the highway...
Typically ran her 75 mph most of the time.... no issues.....
As for the c10, its been sitting a couple weeks, i kept getting a 30 something AFR (lean), and it would threaten to spit thru the holley efi under any load, overheat, etc etc. I told myself this wouldnt be a rushed project , and it wont be. So i work on it in my time.
Today, (this am) i checked the fuel pressure, had the wife cycle the key twice... both times, 20 psi... yucky.
the holley needs to see 60 psi to function.
So, i guess i get the jackass award for not just buying a fresh new Acdelco ep381 fuel pump, and installing it with the new tank and sending unit when it was on the lift at my buddies house.... meh whatevs. ..
Tank got pulled today, new pump ordered.
EZ. Left myself enough line slack that dropping it was no problem, even with 14 gallons of 93 hehe
Ok.
So moving on , i recently got an automatic column from a 70 something c20, so i pulled the old zip tied, jerry rigged 3 on the tree column and swapped in the auto column today, also removed the old clutch stuff as well.
All that i need to do is button up electrical, put the dash back together, and it'll look decent.
Only complaint is the hole in the floor where the clutch rod used to be (directly below the column)
Is there a cap i can put there to cover the hole?or do i now have extra vented AC?
Doesnt really matter. Its not a show truck, its just a means to disappoint the local LS boys.
(Joke) some of them are my buds.
Vbb199
Salisbury NC
Vince
Got a phone call yesterday from the tranny guy; case is cracked. I just told him, 'No leaks', period!
I gotta have a talk with those lottery people.
What case do you need? I got several gutted automatic shells. I buy "bUrNeD uP" automatics for borderline rape prices then gut then for OEM hard parts that would otherwise cost 100's to replace in my personal transmission builds.
Its a nice business model, except i keep breaking stock parts and then reusing what i have stored away :happy175:
Snoots
Roger
Jimmy Sierra
350 w/203
What case do you need? I got several gutted auto shells. I buy "bUrNeD uP" automatics for borderline rape prices then gut then for OEM hard parts that would otherwise cost 100's to replace
Guy says he can TIG weld it and it'll be better than new. Several people recommend him so I'll stick my neck out.
Thank you for the offer tho!
TH350. Got over 490,000 miles on it so I'm not going to go over the edge about it.
Vbb199
Salisbury NC
Vince
Yea, nothing wrong with that, when i encounter a cracked case, it also gets tig welded
Vbb199
Salisbury NC
Vince
Also make sure you replace your bushings for the driveline... thats usually the #1 tranny and t case killer
Snoots
Roger
Jimmy Sierra
350 w/203
Yep! All seals and bushings are getting replaced. And he's going through the pump and discs. It shifts and holds perfectly so I told him DO NOT mess with the valve body and put a brass screen filter in it.
Vbb199
Salisbury NC
Vince
No no i meant the rubber bushing under the t case, and the motor mounts. As well as the torque rod that runs from the case to the trans.
If the trans is allowed to twist too much when you give her the juice, it can crack the trans ,or case of the transfer case.
And also, why no valve body? Ash (spent clutch) gets trapped all in there and around the valves and the VB gaskets deteriorate and break down and fluid can squeak thru passages
Snoots
Roger
Jimmy Sierra
350 w/203
I'm just going by 'If it ain't broke, don't fix it'.
It's getting all new mounts; motor, tranny and x-fer case. Driveshafts are back after balancing and new Spicer U-Joints. New Yukon rear axle shafts and bearings. New rear brakes. Whole lotta stuff getting done. And yes, it does have the torque rod.
Thanks. I DO need reminding about stuff. Too much in my basket these days.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Well today at break i hooked the cables to her with the mini square, gave me hassle startin but got her fired up and let it run for about 45 min. No drive today but i got the juices flowing.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Where did you get patch panels that thick? I need some floor supports inner and outer rockers and cab corners. I’d rather get thick stuff if that’s snootily.
Ben
@Itali83 Heres the mic thickness of them. Inner rockers then floor support.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Well today was my weekly half day at work and it was gorgeous out. I was wanting to swap the gauge cluster in my mini square but since it was so nice out and my "faded to peach" orange paint was really bothering me i got out all stuff and repainted my orange accent. Much better!! The gauges will probly be this weekend. I found a very nice set of full sweep gauges in the local you yank it and popped led bulbs in it. Im excited to see how they look at night. @idahovette
idahovette
Weiser Idaho
Perry
K20-K10
@78C10BigTen 2 things, I have another cluster like yours except no PRNDD21, (5 speed) , and Kooper and I can't "like" your orange stripe because the Combo Black and Orange is our school rivals colors!!!!......but it does look good!!!.........kinda liked the "peach".....lol
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
What now the Big 10 rots and and your rocking a dime?
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
I gotta make some other things happen before it can be repaired. S10 was a cheap, well runnin junkyard grab right at the time i could no longer drive the square.
titos79
