Yesterday on break at work i got the jumpers out and fired her up and let it run a bit. Man i hate seein it in the mirror instead of from behind the wheel.
The ol girl needs to be on the road again!
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Can't you just tag it as an antique and drive it on the weekends?
Right now its gunna go and be re bodied and back to daily then ill send him the s10 to re body.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
God Bless Texas! Went to remove my front sway bar and bushings, etc for a refurbishment, heard tall tales and dark horrors of removing the bushing bolts: torching them out, breaking, drilling.
They came out just fine.
Boy do i love southern trucks.
MAJOR UPDATE AS WELL: Jimmy has been moved to the garage in which the wiring remodel and first start up will be done! Hoorah!!
80BrownK10
Greenwood, SC
Nate
Well it’s been a while I’ve been busy as hell; but managed to get some done to the ole girl. New shoes,(33/12.5/15) set me back a good bit but it needed them bad. Finally got it painted! Satin olive and my wife suggests black trim.
Man I like that!!
80BrownK10
Greenwood, SC
Nate
Weird, I'm only 3 years older than you!! There was plenty of white letters when I was in HS and in college! I never got into the Bro stage and painted everything black or had black rims and all black tires. Still put white letters out on everything I have. Wife won't let me on her Sequoia though!!
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
I got the swaybar bushings replaced yesterday. I'm in the process of replacing the carpet and seat reupholstered. The carpet is installed but waiting on the seat.
was about to ask how you got the new bushings in, but then i saw you cheated!!!
80BrownK10
Greenwood, SC
Nate
It’s ok, better than nothing. The cupholders aren’t good for anything more than cans. But I take corners too fast for a bench seat, I needed something to lean on [emoji23] The Snowden one in the floor is better for actual cupholders
Sent from my iPhone using Tapatalk Pro
Does it open up for storage?
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
Tore apart the front suspension to swap springs. When I bought the truck last year, I rebuilt all the suspension and steering cuz it was worn out. The truck had 2.5” McGauphys spindles with stock springs with 1 coil cut and a flip kit. I swapped in big block c20 springs with 1 coil cut, added Belltech SPs and it rode much better.
Fast forward to the LS swap being done, it now rides like **** cuz the LS is about 150lbs lighter up front and also the nose came up about an inch from where it was. I could feel every little crevice and pebble on the road. So I swapped the small block springs back in and also trimmed the passenger side to help offset the lean from the tank/battery/me being on the left. It rides so much better now, much smoother. Need to pop the passenger spring back out and trim another 1/4 coil or so cuz it’s still ~1/2” higher on that side but it’s much better.
didn't get your new shoes on yet?
80BrownK10
Greenwood, SC
Nate
"What have you done to your square lately?"
Took it out on a wood cutting excursion Friday. Got limited by the daylight, was basically dark by the time I loaded the second tree.
hoagster
California
K10, 1500
5.3l
Shot another door, the other half of the tub and half of the drivers front fender with primer! Man I have a lot of sanding to do.
GorillaHumper
