bluex
Spartanburg SC
C15
I'd check into making sure it worked too. I forget what issue Retro ran into on a truck and couldn't use it when he thought he could. I forget now what that issue was.
From what I remember it's something about the splines on the box but I could be wrong....
83K5guy
Corpus
Justin
K5 Blazer
Pulled front tires off to remove calipers to replace with new ones tomorrow.
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
In the last couple months ive twin sticked my 205 (ord) competition motor mounts (ord) put new black carpet kit in it dynomat floor for starters. Ive also put new rotors pads hub seals on the front. I put new brake cylindrs and seals on rear,pinion seal on the rear. All new power steering lines+ pump power steering cooler off a ford. to name a few that i can remembr right now im in the middle of putting a proportioning valve back on the rear to stopem from locking up
I scored a free 2wd SM465 recently. Best part is, it has the aluminum top cover and a new shifter for less dump truck like shifting. Not what I was looking for, but better than the th350 with slipping reverse.
bluex
Spartanburg SC
C15
One down, 3 to go....
Hopefully my other cross shaft comes tomorrow an its correct so I can knock out the other upper tomorrow night. :D
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
454 TBI TH400 4:11 gears
put new water pump , fixed high idle problem , install 7 way connector , and added andersen weight dist hitch reciever, got some more work to do.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Nice work! Almost makes me want to clean up the arms on my truck a little more...but, nah, it's just a work truck. :D
Black Betty
ohio
Jake
K10 4x4
305ci
Going to try and put rhino linner on my wood in my stepside bed...anyone ever done that before?:33:
That should be interesting :hmm: I'm not sure I've heard of that before. I'd always assumed it was made to adhere to metal. I guess we will find out :popcorn:
Artelt
Ft Hood TX
K10 SIERRA STEP SIDE
305/5.0L
my step side has a rhino liner from PO on top of the wood, now I dont know when it was put on but the wood underneath is real weak and rotted, (way too flexible) but it does seem to be holding up well as far as sticking to the wood.
bluex
Spartanburg SC
C15
Thanks, i just finished painting it now. Its nice having access to a sand blaster. I won't be able to use it on the lowers though because they are to big to sneak in work lol. Im going to pick up a wire brush for those....
MrMarty51
Eastern Montana
Martin
Working on putting the transfercase together, taking pics. as I go, camera battery goes dead, nope, no new batts; taking pics. with the cell phone, run into some complications, forgot to take pics. of the most of what was left of the reassembly.
Take away My rep points. LOL
May I ask why? The nice thing about the wood floor is it has a lot of the same characteristics of a spray-in liner already.
Ehh I'm not sure about that, but I think I'd also reconsider. The wood bed does certainly add charachter. I could see doing the bed walls, and the strips though. And the fender wells if it's a Fleetside bed. I just think I'd leave the wood OEM.
What kind of wood is it? I love the wood that was used in the early 60's. I'd just that some good thick clear that's resistant to water and UV. The Sun destroys the wood almost as bad as water.
Hmmmmm, well maybe a ban is in order. :Sumo: Should be do a 3 day, 5 day, 30 day or ...:shrug:
jimlayhee
