Camar068
Kentucky
10 yrs Air Force
added 6 oz of seafoam to the oil. It's my daily driver so it'll be close to 300 miles next weekend and I'll change it, unless the oil is black before then.
It's about $7 for 16 oz. You can catch the 20 oz bottles on sale but you gotta buy 2 (autozone). Appears to have cleaned some stuff out. It wasn't as dark last week.
I'll continue doing this before oil changes. 5w-30 Full synthetic Amazon oil. Did some research and the numbers are close to Amsoil. Better than your typical brands believe it or not.
https://www.amazon.com/AmazonBasics-Full-Synthetic-Motor-dexos1-Gen2/dp/B07C5VJFBF?th=1
eskimomann209
Modesto
Marcus
Forever sharp steering wheel/ hub. While I was in there I added the cruise control lever. This is the one that works with the 96+ truck cruise and doesn’t need relays to switch between normally open circuits and normally closed.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Bought the rear brake hose last night, PB Blastered the fittings last night, and again this morning. Big one won't come loose and is getting a little sloppy, so rather than completely fubar it I quit.
Even bought some metric Duralast flare wrenches today and still no love. Not metric flares - now I have some, tho.
Flare fittings and I = :gunner:
Who makes a good 3/8 - 7/16 combo flare wrench?
I might try one more time with a known good wrench before I completely abandon it to a full time wrench turner.
So, I said I might as well accomplish something, and did a gravity bleed on the brakes and topped off the oil, then topped off the gas.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
At the absolute worst id use the tin snips and cut them at the fittings and change the hard lines too. Done it before, also resorted to splicing in a compresion fitting in an "inconspicuos" location.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
May be what the pros wind up doing- looks like my efforts are starting to round the damn thing. :flamingdevil:
I hate these things.
On the plus side, this was an attempt at PM, so no emergency rush, and it is not leaking.
I might try again if I can get a 1st class flare wrench.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Did you try the vice grips clamped super tight on the fitting?
Turbo4whl
Downingtown, PA
Wayne
Jimmy
I might try one more time with a known good wrench before I completely abandon ........
Snap-On Tools.
Someone once told me, "You will never be disappointed if you buy the best."
Yes very expensive, the wrenches and sockets are worth the money.
Note: 10mm sockets are not warranted for loss.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Snap-On Tools.
Guess what vanished a few months back when I was working on the lawnmower, in the driveway.
HOW?!:think:
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Yeah, but I just tapped on the end with a hammer hoping vibration would help move it.
Too bad parts stores don't sell upper end tools- not sure what a Snap On goes for, but I would probably try it.
That **** better have a beeper on it to find it if it wanders off, though...
:headbang:
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
:headbang:
In this case id go buy new line and cut it right at the fitting, put the socket on it and twist it loose. Just be easier.
More info on the cruise lever please! Where can I find one? Is it a factory lever from the early 80's or aftermarket?
Snoots
Roger
Jimmy Sierra
350 w/203
I feel/felt your pain once or twice. New lines and cylinders using anti-seize fixed it.
GorillaHumper
