Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Took her out to a public board launch under I10 at the Old and Lost Rivers turnaround .
Drove down a flooded gravel road and put her in 4wd to exercise her.
Saw some mud to play in and would have loved to really try the tires and exercise the 4wd for real, but no one with me , so Bwack Bwak- I refrained. :(
Back at home, with a little mud on the side.
May go back and get some pics - just don't always think of that ...
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Found a real knob in the junk today!! Score!
How you get it to stay on - glue ?
Seems like when those things came off once, they never really stayed in place after that.
Electrical tape has been used previously , but just a short term fix ...
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
It pulled off the lever pretty stiff and went on my shifter about the same. Its just pushed on
fmxr47
US
Justin
Just switched out the dimmer switch, PIA with the column in the truck but I got it, propped it down an inch or 2 and was able to squeeze my hands in. Now I’m getting ready to pull the batteries and install a relay headlight harness.
DanMcG
Central NY
k10 k10
Ended up polishing all the front end stainless steel trim and installing the grill. looks better than my avatar.
Got it all together and realized I forgot to plug in the directional light sockets. D'oh!
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
LOL - went back, and took pics.:D
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
A few moar - done now.
Shorty81
Baby Boomer
North West ohio
Darren
Went back old school for the time being! 16.5" tires are getting harder and harder to come by. Going to be swapping better A/T's onto the old slots so now that they're off the truck I can demount the tires and get them cleaned and polished back up before they go back on.. But the OG look is really starting to grow on me!
LIKE !! LIKE !! LIKE !!
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
That was a suggested option but I don't have a problem running a converter, even if it's one that's not as efficient as it could be. I'm all for helping the environment, just not to the point where I'm willing to buy a new $300 cat every few years. Besides that, with my luck the minute I install a straight pipe Cali would start doing random roadside inspections like they already do with big rigs.
You are correct. I'm hearing horror stories from credible sources about CA and NJ roadside inspections resulting in thousands in fines and corrections.
Granted, that has more to do with newer diesels with cat and DPF technology, but I would put nothing past these people.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Damn! And DAMN! That truck looks good.
Get a set of steel 16s and nobody will know the difference. These trucks looked good coming out of the factory. I understand customizing, but we are getting to the point where stock looks so different that it becomes a custom look to itself.
Own it!
fmxr47
US
Justin
Got the headlight harness installed, had to switch some wires around because the low beam and ground wires were in the wrong spot for the harness . Had a power wire that wasn’t properly crimped fall out of the fuse holder, fixed that and it works great. I’m hoping all my headlight issues will stay at bay, I will soon be installing some sort of aftermarket lights. I haven’t decided on the style I want yet or at least my bank account isn’t ok with the style I like [emoji51]
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Even halogens are bright enough when they get full power.
B.K. Cunningham
Spokane, Washington
Bryan
25 Hundred
Went and picked up a 74 long box to cut up and use fix my 74. It has a 74 chevy gate and the original tire carrier. The blue and white is a heavy half body swapped onto the 74 3/4 frame that the bed came from. Dude also had a sweet cucv.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
That bed have 2 gas holes?
seanhatesregister
