Joshua8336
Dirty South AL
Joshua
I didn't do it today, but I stripped the cab bolt on my 85 a few weeks ago, been trying to figure out how to get it out ever since, tried vice grips, I have no access to heat, bought a few drill bits that broke, i'm out of ideas. anybody else got any? it's a thread stopper fo sho!
Are you talking a cab mounting bolt? If it's what I think it is, as I was explained to, cuz I have the same issue on an 85 cab, you will have to cut a small square in the floor of the truck to get access to the other side. If that's what you mean by stipped. Mine is spinning on the other side.
Look what I finally got done !!! Whooda Thunk it woulda ever happened. Woulda had it done several days ago but.... Nonetheless, it took me a good long while to get it ready but I did.
attachment.php
Thanks again dudes. :love62:
heffalump
Lafayette ga.
jeremy
2500 suburban
Took the brush guard off the burb and cleaned off all the rust and ****** paint... Re-painted it with a good primer and bedliner in a can... Turned out looking good with only a little texture to the paint
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Drovethe 84' for the first time in a few weeks. Driving the Caprice really made me appreciate the fresh suspension in the 84'. I was veering all over the road because I was used to the play in the Caprice steering. :D
I'll probably be rebuilding the suspension on the Caprice this fall sometime.
pontiac6269
Sparta, WI
1981 & 1985
C20 & K5
350 & 305
Plowed the driveway today with the 85 K5 Blazer.
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
Replaced my plug wires today. The headers burnt up acouple of em was runnin like crap tack jumping all over. I splurged and got the msd super conductors for headers so hopfully theyll last at $100 I dont wanna replacem every year. Funny any time I fix or replace anything I feel like it added 100hp for acouple days then it wares off. Then want to fix something else to get the high again
Goes to show you. These trucks are addictions just like drugs. Always chasing that high just like first time. :rofl:
Keep them plug wires off the headers. Doesn't matter how good they are, you touch the headers, they're going to get trashed.
I gotta get off this computer and go get some work done, a gutless stepside is calling my name.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
I got the 90 90 plug ends set there comin straight up out of the headers. They might be touching the flange ya think itll burn em up still it was the only way I could getem on
Stewzer55
Ohio
Stew
R30
Keep thinking about how much I need to get it down here and start making it roadworthy again.
Did some general maintenance and a few minor repairs to Porky. Steering box bolts were loose, carb needed adjusted, fuel filter and line needed replaced/rearranged, pcv needed hooked up, oil needed changed... that sorta stuff.
Also got the engine/trans about ready to pull out of the C10, just a few more things and it's outa there.
v2500burb
Charlottesville Virginia
Jay
v2500
350ci
Getting the Burb tinted on Monday....
Summer is coming!!
Also doing valve seals and will be tackling my AC!!!
datto62073
Monroe
Mark
swapped the steering wheel, fixed the turn signals, figured out the dome light issues, temp fixed the reverse lights, and some other stuff. its been a long time since i worked on a gm product even though i have my caprice that i need to fix.
Jimc21NC
