Irishman999
- Jul 30, 2010
- Safford Arizona
- Jason
- K-1500 High Sierra
UUhh....Why?
A rain storm was rolling in haha.
UUhh....Why?
Width is the same too right? I'd imagine the 3/4 tons are just a stiffer ride. You know a small block in a half ton and a small block in a 3/4 ton weigh the same. I'm pretty sure my 4in front lift springs are of 1/2 ton caliber. But, I fully intend to upgrade the rear springs on my K10 from 52 in 1/2 tons springs, to C20 56 in 3/4 springs by moving the rear spring hangers rearward using the factory OEM punched spring hanger holes and adding the 3in lift blocks so it should sit level to the front 4in lift springs. If anything, I might still be a little higher in the rear. Also going with 3/4 ton axles and driveshafts.
Double Dingo wjere did you find the matching lockin gas caps?
Today converted my Quadrajet from vac secondaries o mechanical secondaries and ordering everything to do the left tank and get a new fuel valve to get both tanks working right. Thought I had it working the other day till it left me stranded with no gas in either tank because the valve was stuck in between left and right and sucked both tanks dry lol
Luckily i was within walking distance of the house but unfourtantly the family was with me and it was after 1 am and they had to walk too. And now that i ran it dry and sucked up all the **** in the bottom of the tank even with a fuel filter the float is now sticking every once in awhile
spent the day chasing header leaks. rehung all exhuast pipes. then took her out for some excersise.replacing window motor tomorrow. been a great day its finnaly cooled off.
