What gears
chris3353
idaho
chris
v2500
I have a 89 suburban 5.7tbi, 4L80 14 bolt and run 456 gears. I get ~12 mpg around town and ~15 on the highway. I cruise ~65.
Blazerbiker
Rifle CO
Stephen
K5, actually a Jimmy since it's a GMC
504in
I've found 4.56s and 35s with the TBI350 to be a decent combo. Still very power limited but at that point it's mostly a power problem, not a gearing problem. I will say you should not be afraid of "over gearing" it. Your 30% overdrive will soak up a lot of gearing. If you're serious about 37-38" tires, at least 4.88s and maybe even 5.13s are the way. I'd do 5.13s. We've geared a couple GMT800 trucks with 6.0L/4L80 combos on 37s and 4.88 puts them at about stock rpm for a 2500 truck but you have a deeper overdrive and less power. Thus the 5.13 recommendation.
I hate to be the guy recommending smaller tires but with limited power, I'd consider keeping the tires smaller and like was mentioned earlier, maybe bail on the 14B front too. A GM D60 is a really solid system that seems to have gotten a bad rap somehow lately but they have always been able to take about anything you can dish out in a K5 on anything less than a 42. Keep in mind also that once you go past about a 37, your 241 quits being a rockstar and becomes something you need to think about.
Really hard use is not a slippery slope, it's a cliff edge you step over. Past 37s and you need strong axles, hydro assist, the tires themselves which are typically on beadlocks, power to move all of this with a trans that can take it, T-case strength and so on.
Moral of my story, put 5.13s in a GM D60 front and your 14FF rear, run 37s and go camping. Coilovers in front with our leaves in the back is a great system that will drive nice and have really good offroad capability too. And our coilover system works really well with a GM D60.
Red3833
Huntington Beach,Ca
Frankie
k20
5.13 are the way to go..
I have 700r4,205, 4” lift, 14b, 35” tires. cruises 75 no problem, one of the best upgrades I have done.
I like having option of going bigger tires,lift later on
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
454, 4:10 205 14FF rear D44 front lockers in both. we have seep hills, truck does well here.
hack_man
MA
Tony
Do the higher ratio gears cause either the ring or pinion gears to get weaker because the teeth are smaller since there's more of them?
Yes,steeper gears are weaker,but at the power levels we are dealing with I don't know that it's a problem.
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
I would love to get a dana 60 for the front just can’t find them. I need a passenger side drop and want kingpins. Shoot its hard to even find ball joint one
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
Might of found a 60 with 4.56 gears out of a 84 cucv m1008. Will this bolt right up? Doing the research now, just wanted to ask here also
nvrenuf
Mobile, Al.
It’s a direct bolt in except for the ubolt hardware.
kobedemello
