What gears
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
Hey Guys. Need some gear ratio suggestions. So just got some one tons 14ff rear and getting in a costom 14ff front passenger drop. Going to start building up the rear pulled it out of a 2000 Chevy 3500.
They will be going in a 1990 blazer with stock 350 tbi 700r4 and np241tcase. 35in tires with 4in lift. She will be a daily driver and will be going 70+ on highway. Was thinking might go up in tire size a few inches. Anybody have the same set up and what do they run? Thanks for all suggestions and any replies. Trying to get to stock numbers with the changes
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
What would be better of the 2? I was thinking 4.56 but will it still be good if I upgrade tire to 38in
nvrenuf
Mobile, Al.
Having overdrive allows you to run more gear than the typical 3spd truck (of that era). Also having 35's now and wanting something bigger really means you need to be choosing a gear ratio for the future, not today (even if they are installed today). Gear swaps are expensive and require a certain level of expertise, so you don't want to do it twice.
Personally, I would look at 4.56 or 4.88 gears for tires in the 37"~38" range.
@PartsMan79 is dead on about the bigger tires and weight, they're fun but they add quite a load to a truck.
Something else to consider, 14 bolt front axles are BIG and hang low so with smaller tires (35's) that thing is going hit / drag on everything. If you THINK you might not go to a 38" tire you might consider a typical D60, this could save 2"+ of ground clearance at the diff.
I would go 4.88. That is a lot more tire weight and wind resistance than the stock tires.
Yep! Exactly!
Keeping rpm/speed ratios similar to stock doesn't work with more rolling resistance and more wind resistance. Especially when trying to mimic the tall ratios GM did in the 80's.
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
Thanks guys, as for ground clearance, I’m thinking about shaving the diff which will give me anywhere from an inch to 2 inches depending on how I shave it, but I’m looking into that and seeing if that’s a long-term reliable option. The website grim jeeper I know about that I’ve been on there looking at stuff and seeing what the speed and RPMs would be at, just wanna cover all my bases before I purchase gears so now I’m leaning more towards 4.88 might be a better option for when I do go 38 tires I might go right to 38 as soon as the axles get put in. Just want to really make sure, seeing as this will most likely be a pavement queen just good driving, but it’s always good to be able to go off the beaten path I do like to explore. but nothing too crazy not rock crawling or anything like that (for now lol) but I do like to camp.
alittle
