What fluid stains do your daily drivers leave?
idahovette
Weiser Idaho
Perry
K20-K10
My thoughts on this is the cause of those black stripes may be from adrenaline leak making the right foot press heavy on the accelerator pedal. This is a normal condition for car guys
I've always told Kooper when he drives the Chevelle(not often) right foot down left foot up!!!!!
80BrownK10
Greenwood, SC
Nate
Even if you're buying bargain no-name oil at $3 a quart, pissing through that much every day you could easily afford a junkyard head and a cheapo gasket set after a couple months. Skip the machining if you really don't care and just want to be cheap, it'll be better than a cracked head that bleeds oil. Unless you're just counting the last few days until you scrap it or something, but it's a 10 year old car, besides the cracked head how bad can the rest of it be?
You can but oil for $10ish/5 qts so a little cheaper . But I still get what your saying and agree.
ali_c20
Austria
Alexander
C20, K5
None. It's an Audi. No leaks and it's 11 years old. Must be the fault of ze german engineering. I have my Squares and my Impala for marking everywhere I've been :)
Green79Scottsdale
G.R. - MI
Bob
My daily, '01 Montana with 226k, leaks oil from the distributor plug gasket. The body also leaks metal flakes at a consistent rate.
My square leaks from... everywhere. Unless I drive it consistently. Then the seals revive themselves and its fine.
350 w/203
NONE! I keep all aspects of the drive train in good repair and don't procrastinate when something does develop a problem, it gets fixed. I discovered early on that engine oil is much more efficient as a lubricant if it remains inside the engine. this applies to all other fluids as well!:cheers:
Show off.
350 w/203
Daily driver - none. Which is not a surprise since it is a 2015 with 85k miles. My wife's daily is a 2013 with 159k and doesn't have any leaks either.
The square only has one and it's the oil drain bolt. I can live with it until next oil change and put a new one in.
Here ya go. I'll try to locate the p/n. It is a GM part.
Found it! GM part number:
14090908
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
The Mighty TDI tends to leave an oil spot. Although it's a lot less since I fixed the oil cooler.
Strangely, the square doesn't leave any stains since I fixed the transmission cooler lines. Now it just generally sweats oil, but doesn't leave any spots. Sometimes I think a little leaking is better. It makes a good rust preventative.
Midnightmoon
Pennsylvania
Justin
My 2007 Cummins 5.9L likes to leak from the rear seal. I just put a new one in approx 15K ago when I installed a new clutch. It's leaking again. Before that, the oil pan rusted through on the front corner. Not to be outdone, the steering box seems to be wet now. It's not dripping on the ground yet. But, give it time and I'm sure that it will.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Far as i know my suburban doesnt leak anything except a teeny tiny bit of ATF from the speedo gear cover on the trans.
Just fixed the s10 blowing ps fluid past the cap today, swapped the current fitting with another High pressure fitting with a smaller drilled ID, and modded my valve for 1200 psi instead of >1400 psi, as well as stretched the High RPM return spring a tad bit more
No more leaks :gr_grin:
jjester6000
Illinois
Jack
C1500
My yellow truck runs real good and smooth, but has low oil pressure and some pretty worn main bearings.
(I found a couple metal shavings on the dip stick once)
It was starting to rattle a bit, so I just changed the oil with 5 quarts of 20w50 (I had been topping it off with 10w40) and 1 quart of 90w140 gear oil (no joke).
No more rattle.
Thank god I have a block heater, or I'd probably break the oil pump drive shaft.
It has 80-100 psi in compression on a good day, and to seems to have piston slap and some minor rod knock.
jjester6000
Illinois
Jack
C1500
I started the Burb to warm it up this morning then went back inside,slicked my and got dressed. I come back outside to discover that it quit.
I then noticed that the gas gauge really meant it when it said E, (you can usually get about 90 or so miles out of that 42 gallon tank after it says E) so I had to take 'Ol Yeller to work today, and was pleasantly surprised that the rear main seal leak has been significantly slowed by the real thick oil.
Also, you should see this brutal cold start I did on it in 20 degree temperatures.
kobedemello
