What color is the wire for the fuel gauge?
jfkelley
Oklahoma City
I have a 76 K10 I'm doing an LS swap in it came stock from factory with dual tanks..Im going to one tank with electric fuel pump inside the 87 TBI tank on the drivers side I want to use the factory wiring so I can run the factory fuel gauge ..My question is can someone tell me what color is the wire for the stock the fuel gauge ?..I see two blue wires and and a black wire which is ground...But I have read on other forums its a pink wire I'm looking for ?..Can anyone confirm this ..I am lost when it comes to wiring...Thanks in advance
The wiring for a ‘76 would have the right tank as main and the left as auxiliary. It also uses a simple Pollack valve (either 3 or 6 port) for fuel, with only one power terminal to make it switch. Later trucks made the left tank the main, and used a 6 terminal fuel valve.
IIRC, the gauge sender wires on my ‘75 are tan, not pink. The main tank sender uses a tan wire and the other is tan with a white stripe.
Are they perhaps a faded pink that turned to a tan-ish color?
jfkelley
Oklahoma City
jfkelley
Oklahoma City
I have connected my sending unit wire to both Tan with White Stripe and Tan ( Maybe Pink Faded wires ) one at a time and it goes all the way to the 3 o’clock position.. am I doing something wrong?.. The wires I have on the driver's side are the following ..Keep in mind this is going to be the tank I use and there is no gas in the tank , I can hear the fuel pump kick on when I turn ignition.
Thick Red wire that runs all the way to the back
Blue
Light Blue
Pink maybe Tan
Pink With White Stripe ( Could be faded tan)
Green
On passenger side there is one Tan wire with a white stripe leading to front of Truck ...
Am I missing something?..I checked the ground...Thaks In Advance
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
My ‘80 with dual tanks is a pinkish/tanish wire. It’s here on the bulkhead IIRC:
ETA: looking at my notes I may have it pinned in the wrong spot, I think it should be in the hole above that.
jfkelley
Oklahoma City
If I understand this correctly I attach my Sending unit fuel gauge wire to the pinkish tan wire ?
CalSgt
CA
Casey
With factory stuff it should only hook up one way... My factory sending unit wire had a kinda unique plug on the end.
jfkelley
Oklahoma City
Ok I think I get it ..That wire connects to the back of the Fuel Gauge ...? Am I wrong?
CalSgt
CA
Casey
Yes, through the bulkhead & to the gauge. The rest of the dual tank wiring goes through the firewall in a different spot.
Ken B
indiana
ken
where can i find a replacement sending unit wire? mine is cut and the pop on end is missing ? anyone know who carries this?
I'd like to know this as well. Previously, I have just scavenged and replaced the connector with an old used one.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
https://www.summitracing.com/parts/aww-ca97607
Ive never pulled that connector apart, but this seems correct other than wrong application with the little pass through grommet. There's a couple other options in the related section.
I always thought mine were orange wires..
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
82jimmy
