WFO
- Jan 6, 2017
- Texas Panhandle
- Dan
- K20
I think I'd only put it on for inspections, and leave it off the rest of the time.
Let me get this straight, it runs fine the way it is but you want to mess with it?
OPs getting a lot of **** for asking a basic question LOL. trying to get more air into the intake is like the most common “upgrade” made. It’s not unreasonable for him to ask if removing it would help. Engineers engineered **** for smog reasons a lot and not for efficiency. And sometimes for efficiency but suffered a few mpg. Also they would sacrifice both power and efficiency for cost cuts.
Maybe he wants to improve his gas mileage? You know every squarebody owner has to ask at least once.
Run propane with 10.5 - 11/1 compression. Anything bigger than a 350 will need 2 mixers (propane carb, Impco 425). The second mixer and regulatorYeah, now that's funny! Good fuel mileage in a Square.
Fun Facts:
The GM Square trucks, dubbed as the "Rounded Line" were designed when gasoline was between 30 and 40 cents a gallon. No one was thinking about fuel economy.
Sure, through the Square years attempts to lighten the truck took place. The 12 bolt rear axles in the 10 and 1500 series was replaced with the lighter 10 bolt. The heavy transfer cases were gone along with the turbo 400, base automatic. Did you know that a turbo 400 shares some of the same size clutches and steels as an Allison AT540 MD trans?
Most of you know the glass got thinner but many little items went from diecast metal to plastic. Window cranks, Heater control brackets, and even the speedo gear box on the gauge to name a few.
You want better fuel mileage, rip out the power seat, power windows, power locks and the complete AC system to name some stuff you don't need. Put skinny high pressure tires on. This will get you a few miles per gallon.
(evaporator) can be on an electric solenoid gas valve. You can run on one carb but power will be low. Hit the Mad Max switch for the second carb and ROAR!
