Water pump failure destroys radiator
gmachinz
Harnessworx Inc
Iowa
Jabin
All I can say is I don't think I've ever heard/seen an electric fan setup do that.....just one more reason...lol
74 Shortbed
I'll be going with electric fans on mine..
austinado16
Central Coast, CA
1990 w/307k miles on the clock
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
I hear you guys!
What do you think about this set up, for a 2012, 2500 Suburban:
$20 Hayden, adjustable fan controller from RockAuto
$160 dual fan setup from RockAuto
Would it be safe to say that if this set up cools a 6.0L engine in a 'burb, it'll be more than enough for a small block? The radiator core specs for the 2012 2500's are 34" wide, like what I've installed, and somewhere between 18 and 20 inches tall, depending on how they are measuring.
gmachinz
Harnessworx Inc
Iowa
Jabin
With 34" core width you have room for his monster setup if maximum cooling is what you're after.....but keep in mind this setup is very high end and $625....but it depends on what you're after. With those flexalite fans I don't think I'd trust that single relay w/adjustable temp probe-they are typically only accurate to +\- 10 degrees whereas temp switches are +\- 3 degrees.
gmachinz
Harnessworx Inc
Iowa
Jabin
I just built one for a guy last week and shipped it out-the dual 14" fans are rated at 6000 CFM and I would suggest running at least a 140A alternator as this setup will demand 36-38 amps on high speed. I build them as a parallel running 3-speed configuration using my dropping resistance style relay control harness. It measures (with side tabs trimmed off) 32x19x6.5 inches.
austinado16
Central Coast, CA
That's a sweet set up. I was going to ask if the stock alternator was enough to handle the loads of dual fans, plus fuel pump, computers, and dual a/c systems........my hunch was; probably on the ragged edge of it's ability.
I wish I could afford to step up!
74 Shortbed
Very nice setup.
gmachinz
Harnessworx Inc
Iowa
Jabin
Well keep in mind that a lot of aftermarket fans don't draw as many amps as OEM style fans-so you may be ok with a stock alternator-as long as it's at least 100A. I prefer to use OEM fans mainly from a durability standpoint-the one in the pic is a 2010-up F150 ( I know, I know....lol) fan assembly from Motorcraft. It's the most powerful setup at 6000 CFM that I could find-and this thing is insane on high speed-I bet in neutral it'll pull you to at least 15 mph!
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
If he is still running the stock CS130 as equipped (IIRC), they are on borrowed time brand new, without electric fans. The performance at idle would be very poor.
austinado16
Central Coast, CA
Yes, I'm still sporting a stock alternator.
austinado16
Central Coast, CA
All back together and runs fine again.
The reverse rotation 454 fan fits fine, but the leading edge of the blades is just slightly rearward of the shroud. I'd like to see the leading edges forward more, like maybe an inch.
The blade tips touch the top radiator hose if it's installed in the C shaped metal clamp that holds it to the shroud on the driver's side. For now I just have the hose sitting up on top of the clamp, but I'll have to resolve that situation.
I installed the baffle that closes off the driver's side end of the core, so that was a nice upgrade. A few photos for your viewing pleasure....
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Man thats pretty cool. I still want to do that upgrade some day. Too bad the parts are just so hard to come by. NOBODY parts squares down here in FL anymore. They just aren't around.
austinado16
Central Coast, CA
It's become like that around here too. We don't have rust, so there are a ton of them on the road, mostly as pickups and Suburbans, but pretty much gone from the yards. I was really lucky last week; they had a 6.2 pickup, and 2 TBI Suburbans, one of which was 2WD, 454.
If you're interested, I still have enough parts to do one more conversion. I've got a fan shroud, the top closing panel, and 2 top radiator mount plates/brackets, and I have a 6.2 radiator. You'd need to take the radiator to a radiator shop and have your SB tanks soldered on.
gmachinz
Harnessworx Inc
Iowa
Jabin
That fan is a BIG upgrade vs stock that's for sure!
austinado16
Central Coast, CA
Yep. The only thing left to do is to use some sheet metal, attached to the existing shroud, in a hoop shape, to bring the shroud rearward over the first 1"-2" of the fan. That'll provide maximum draw through the radiator.
seanhatesregister
