VAL
- May 29, 2012
- TUCSON, ARIZONA
- VAL
- K10 SILVERADO
Answers to some of your questions/comments:
The reason the fan is spaced forward is that I've installed the much longer radiator that was only used in the 2WD 454 models. The fan shroud that fits that radiator is not very deep, because the 454 engine sticks forward toward the radiator more. It's a standard fan spacer that's available from NAPA or other sources (not that that means anything, of course). All bolts and nuts are still tight.....so there was no failure there. It's simply a sheered off water pump shaft.
As for the condition of the pump. It is very likely to be an original GM pump, and it could be the original pump, now with 298k on it. I purchased the truck at 224k, in 2004, and I can't remember if the pump looked brand new at that time, or not. I kinda doubt a pump could live 300k, so it may not be original, but the original owners (who I got the truck from) always had it serviced at the local GMC dealer, so even if it's not the original pump, it's an OE pump that predates all the crap made in China (like the Bosch pump photographed above). And that's why I've never touched it......because I knew it was excellent OE GM quality, and I knew if I put something new on it, no matter who I purchased from, I'd be getting China crap that would fail in 18 months or sooner.
My buddy down the street helped me trailer it home this morning.
I was able to straighten out the fan blades with a little finesse from a BFH and an anvil. Hammer-to-fit-paint-to-match.
Photos of the carnage for your viewing pleasure:
Damn, looks like something out of a horror flick!
