washer pump not working
cape square body
orleans cape cod
jpohn
v10
1987 v10 Silverado the wipers work slow fast and park but no wash I tested pump to battery it works
there is power to pump pink and white going to pump pink has power with key on I bought new wiper switch
and just plugged it in did not install in Colum did not work what next to try ? I think there is a wire missing
off of white wire there is a wire connector with a small cut wire coming of near plug see picture
thanks for and advice or where to try next
Jgonick
West Texas
Joel
If I’m remembering correctly (not home currently to check diagram) the pnk wire goes back to wiper switch to ground wash pump when selected. The white wire brings power from fuse block to washer pump. Wipers work the same way- white brings current & the other color wires take it to ground depending on speed selection at switch.
If you have voltage on pnk wire (without hitting wash) it’s wired wrong. Should have voltage on white
cape square body
orleans cape cod
jpohn
v10
Your correct voltage is what any thoughts maybe pink not grounded ? It goes from switch to module to fire wall than motor
Jgonick
West Texas
Joel
Does the white wire at the washer have ~12 volts? If it does, the pink wire is probably not getting to ground (broken or loose connection etc..)
In an 87 v10 your bulkhead (going through firewall) should be similar to the two attachment. I am unable to see the portion that the washer pnk & wht go to in your picture.
projo198
Lawson MO
James
These guys are correct about the wires. I just completely replaced that wiring and switch myself dealing with mismatched harnesses.
The pink does in fact send ground to the squirter motor from the switch though it changes color somewhere between the motor and switch. Best way to test it is with a voltmeter; put the negative prong to that wire and positive to the positive terminal on the batter then see if activating the switch in the cab sends ground. It should not if the switch isn't activated. If the pink wire was worn and touching metal it would have constant ground and you'd be seeing fluid the entire time the ignition was on.
Lastly if you find the wiring/switch is good and the squirter motor is just bad, and you don't want to replace the whole thing, there are a lot of aftermarket wiper fluid bottles available with an integrated motor. You would just have to redirect those 2 wires and the water lines to the new setup.
Jgonick
West Texas
Joel
If you have power on white wire at washer and the pink wire appears good to the bulkhead- you could use a piece of wire to jump the pink connector to the black connector at the module to see if the washer works. If it doesn’t -next- remove the module and use the wire to jump the pink and black wires at the connector directly . FYI the wire connector will plug directly into the switch without the module. (The module just adds delay if the module is working correctly)
You mentioned, in another post earlier, the wipers work on hi and low- that indicates the black wire at the module is grounded correctly.
gmbellew
Kansas city
glen
suburban 1500
I have a similar situation. my washer won't work when it is below about 50deg in the cab. works great after cab warms up and all spring, summer, fall. I have a bad connection in the switch I think. because when I ground pink at the module, the washer always works regardless of temp. I plan to install a momentary switch to ground pink to black in the switch harness at the modile and stick it to the column by the wiper switch as a work around until something else happens that requires the column to be dug into to replace the switch.
cape square body
orleans cape cod
jpohn
v10
Thanks ill try next warm day
cape square body
orleans cape cod
jpohn
v10
Thank you all for input turns out I jumped module and pump worked so removed module and squirter works fine module controls delay and squirter for anyone else with this issue
Broken85
Cumberland, NJ
A
Here is your module (below), which is likely your problem.
The actual wiper switch is the first thing put into the steering column and the last thing to come out. You have to disassemble the entire column. If you end up trying it, I’d recommend you remove the column from the truck and do it on a bench. Doing it in the truck will have you beating your head against the wall inevitably.
Jgonick
West Texas
Joel
Or you could try to fix yours if you wanted to try- here is a post with a video link (later in the discussion) describing how to fix it.
LINK- to post
LINK- to video
cape square body
orleans cape cod
jpohn
v10
well removed module and washer motor works fine
guess I will go with out delay for now
nbrizjr
