Warn Winch Guard Mod
fallguy
Minot, ND
Jamie
Silverado K10
The guard mounted and accessory lights added.
A side support from the guard. Traced onto cardboard and pencil adjustments made.
Template cut out. Winch will be closer to grill by 3" and winch plate will be 6" higher.
Side support removed. As you can see the guard sits too low and covers the license plate...illegal in ND. Plus I just don't really like the look.
Template mocked up to the actual grill. I'm liking how its going to look. A welding shop will cut it out of 1/2" steel and punch the holes.
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
So... Are you modifying it for a better, closer fit? If that the case then I like the idea, I don't like winch mounts that hang way out in front.
carlgm
Fl
Karl
'85
Looking great so far! Any updates? Would like to get ideas from your project.
MrMarty51
Eastern Montana
Martin
:popcorn:
I just picked up an old Warn/Belleview winch, I`m a going to mount to the front of Mine 79 so, I`ll be watching this fabjob.
Thanks for posting this project in for us.
fallguy
Minot, ND
Jamie
Silverado K10
Mod done
The shop cut out the template in 1/2" steel, I primed & painted with engine paint. Most things lined up. I was 1/4" off the bottom hole of the brush guard which interfered with the light. But I got the look and functionality I wanted. Hello license plate and it sits back almost 5".
fallguy
Minot, ND
Jamie
Silverado K10
Template cut.
fallguy
Minot, ND
Jamie
Silverado K10
Closer to grille.
fallguy
Minot, ND
Jamie
Silverado K10
Head on
bigcountry78
James
K10 Custom Deluxe
That looks great, but then again I just like the whole truck in general. I like rollbars and extra lights on these trucks.
brentjo
